Seibon TS hood clearance problem?
Old Jun 24, 2007 | 06:22 AM
Changvi's Avatar
Changvi
Default Seibon TS hood clearance problem?
I just got a TS hood from Carbonlimited on friday. Great looking hood and very well packaged. Thanks Jim! But as i was doing to test fit, for some reason the center section of the hood was rubbing against my Kinetix V+ plenum as it closes; which it prevented the hood from latching. When I tried to pushed the hood in to latch, i noticed the center section of the hood would bulge out. Does anyone have a problem with the hood with Kinetix plenums? Any advice on how i can fix this problem? Any advice would be appreciated. I also raised the stock tower bar to clear the plenum as well.
Old Jun 24, 2007 | 07:19 AM
myehrick09's Avatar
myehrick09
put some washers and adjust your latch all the way up. I just installed my VT a few days ago and I had the same problem. I'm running a 5/16 motordyne spacer with greedy strut bar on my setup. After I added a few washers, problem solved.
Old Jun 24, 2007 | 10:07 AM
TayTaythatsme04's Avatar
TayTaythatsme04
yup the vents look cool and get some of the heat out but the also always manage to hit something. took me almost three months to figure out what the vents were hitting. But after that they fit fine.
T
Old Jun 24, 2007 | 10:20 AM
r0mey's Avatar
r0mey
+1 on everything they said i have a TS too and just had some washers ull be good
Old Jun 24, 2007 | 01:51 PM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Give the washers a try, otherwise there have been members who cut the under skeleton.
Old Jun 24, 2007 | 04:11 PM
KelekonaKustoms's Avatar
KelekonaKustoms
i have the V+ plenum, it rubs on the stock hood too. well at least mine does, it rubs on the inner structure. i just bent some of the inner structure a little and it doesnt rub anymore. if thats were yours rubs, just dremel a small spot on the inner structure of the TS. its just fiberglass, and you only need to remove a very little amount. i have a TS that i havent installed yet, but thats what im going to do.
Old Jun 24, 2007 | 09:23 PM
Changvi's Avatar
Changvi
What kind of washers do I use? Any round washers would do?
Old Jun 24, 2007 | 10:38 PM
Chad68's Avatar
Chad68
I thought you were selling that hood? Hey man if you keep it and get it to fit, I would love to see that hood in person.
Old Jun 25, 2007 | 04:29 AM
lovetoclown's Avatar
lovetoclown
I cut the underside. Still more than stron enough. Washers is just hoig to make the hood stick up to high at the hinges.
Old Jun 25, 2007 | 05:29 AM
clipso 01's Avatar
clipso 01
wow...that looks great
Old Jun 25, 2007 | 05:51 AM
IIQuickSilverII's Avatar
IIQuickSilverII
very jdm look..I like
Old Jun 25, 2007 | 06:01 AM
chsia's Avatar
chsia
Default Cut it
I cut a hole under my VS II hood.
Old Jun 25, 2007 | 07:09 AM
Changvi's Avatar
Changvi
Yes, but i think i will try to cut the underside to make it fit. I'm sure it will fit with the washers at the hinges. If it does not fit, then i wili sell it.
Old Jun 25, 2007 | 12:35 PM
Elohite's Avatar
Elohite
GL with this Vince.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
