Central Console and S2K Start engine button
Old Jun 25, 2007 | 04:34 AM
mb_faster's Avatar
mb_faster
Default Central Console and S2K Start engine button
Hi all, I want to show you my interpretation of central console of dash and S2K start engine button integration into console.
I hope to like you my work.
Picture with work in progress to finish.
Old Jun 25, 2007 | 04:41 AM
NA350Z's Avatar
NA350Z
That is one clean install.
Old Jun 25, 2007 | 04:49 AM
Greedy4nismo's Avatar
Greedy4nismo
nice, that's the way to do it.
just noticed that your temp control was in celcius...at first i was thinking "holy cow this guy likes it cold"
Old Jun 25, 2007 | 05:27 AM
clipso 01's Avatar
clipso 01
very nice...i have seen this done before, but yours looks great......how hard was the wiring part of the project?
Old Jun 25, 2007 | 10:32 AM
HockeyZ39's Avatar
HockeyZ39
Best install i have seen yet, what did you do to make the console smooth? Filler or sanding? I was thinking of doing something similar with body filler to make a more flush fit.
Old Jun 25, 2007 | 10:43 AM
Greg'Z33's Avatar
Greg'Z33
That does indeed look very smooth and well-blended; nice work!.
Old Jun 25, 2007 | 01:32 PM
HitLines's Avatar
HitLines
Ok I must bite, how does this actually start the car?
Old Jun 25, 2007 | 01:41 PM
HockeyZ39's Avatar
HockeyZ39
just like the S2000 does.......... (its a button from an S2000)
but to be more technical it uses relays and taps into the ignition system, so basically the act of turning your key past "on" to start is replaced by the button. So you just move your key to on then push the button.
Old Jun 25, 2007 | 02:01 PM
MustGoFastR's Avatar
MustGoFastR
Looks great! Love the way you molded it in.
For those with questions about the wiring, parts needed and operation of the button mod, see my write-up here:
https://my350z.com/forum/audio-video-and-electronics-diy/220742-s2k-engine-start-button-install-write-up.html
Old Jun 25, 2007 | 02:04 PM
mb_faster's Avatar
mb_faster
Thank you, Im happy that my work like you all.
I used a basecoat for external body and worked with sand paper...5 hours to make a console smooth
For the electric connection I used this guide
https://my350z.com/forum/showthread.php?t=220742
and this
http://www.oichan.org/mods/starter/starter2.htm
Old Jun 25, 2007 | 04:18 PM
Voboy's Avatar
Voboy
wow your center console looks beautiful. I need to get this done!
Old Jun 25, 2007 | 04:24 PM
mw9's Avatar
mw9
damn bro, thats some good work. You ever think about doing some business on the side for people. You should have made a DIY with some pictures of the process of making the dash as smooth as you did. Might be a dumb question, but where are you getting the start button from, like a website or something, thanks
Old Jun 25, 2007 | 06:31 PM
HockeyZ39's Avatar
HockeyZ39
ebay has the full set up with instructions for around 70ish. Or u can get all the parts your self and follow the second link that faster posted.
I would deff love a more in dept write up of how to make the dash so silky smooth, and what paint did you use? Spray!?
Old Jun 26, 2007 | 06:30 AM
iknowitsfast's Avatar
iknowitsfast
man, that is nice! push button z. good job!
Old Jun 26, 2007 | 11:53 AM
mb_faster's Avatar
mb_faster
the basecoat is already sufficient in order to render the surface homogenous, the use of the sand paper renders all smooth then, the color has been sprayed like was a piece of normal auto body.
Old Jun 26, 2007 | 12:10 PM
HockeyZ39's Avatar
HockeyZ39
So basically you didnt do any sanding to the actual console? just after you applied a "filler" base coat?
How much would having an autobody shop spray it cost? Dunno if a Lemans Sunset console would look all that good in my case tho.
Old Jun 26, 2007 | 01:57 PM
mb_faster's Avatar
mb_faster
I advise to you don't sanding the original plastic but the filler base coat.
Is very difficult for me to speck about price, 90 % of work is mine and my friend sprayed the color and finishing coat. He have a body work shop.
I payed he the only material that he used, 50 EUR about 45 $.
I love you color, LeMans Sunset...If I find a pic a post to you, I remember that I have see a Z with orange console....
P.S.
Im sorry if my english is not very good
Old Jun 26, 2007 | 02:10 PM
laswyguy's Avatar
laswyguy
very nice! to bad your not in the states, I'd pay good money for that kind of install.
Old Jun 26, 2007 | 02:18 PM
HockeyZ39's Avatar
HockeyZ39
I have seen the lemans dash just seems a bit drastic to me. Think it would need some more lemans else where on the interior to tie it in also.
I figured u or someone u knew had a shop but thought I would ask anyway, if you get a chance ask your friend how much it would cost.
Old Jun 26, 2007 | 03:16 PM
buffmanjeff's Avatar
buffmanjeff
thats beautiful.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
