Door edge grill comes ott
Old May 5, 2003 | 08:52 AM
steve72852's Avatar
steve72852
Default Door edge grill comes ott
Anyone tried the door edge treatment on the grill and had the pieces come loose? The mod looks great but the adhesive does'nt hold too well. I'm thinking of maybe using carefully applied contact cement. Any thoughts out there? Thanks
Old May 5, 2003 | 08:57 AM
Pitlizard's Avatar
Pitlizard
Default Try hot glue
Steve, I had to use a spot of hot glue at the ends on the under side. That seems to have done the trick. Good luck.
Old May 5, 2003 | 09:35 AM
ares's Avatar
ares
Veteran
I didnt do it to my car, but I had it on the doors of my last car, I found that the adhesive they use becomes sticky in the heat, mine came off a few times, Id just stick it back on...
Old May 5, 2003 | 11:27 AM
Dallas350Z's Avatar
Dallas350Z
Default Mine came off too....ughghg
I put mine on Sat and thought how cool it looked on a chrome silver. It was about 90 in Dallas Sat and it literally just ooozed off. Not sure what the heck to do know. Have enough for another batch, but not sure how to get it to stick better....
Old May 5, 2003 | 12:32 PM
ares's Avatar
ares
Veteran
epoxy will do it, but be careful you dont glue yourself to the car. you need to remove all adhesive that was on it. doesnt the adhesive come pre applied to it? gotta get all that off, then use epoxy, ill hold through the next world war.
Old May 5, 2003 | 12:55 PM
SkyMan's Avatar
SkyMan
im thinkin of just painting my grill a chrome silver colour, im sick of the adhesive...
Old May 5, 2003 | 05:15 PM
all_bark's Avatar
all_bark
I did it recently and love the look.
Mine is peeling off a touch time to time. I just stick it back on. I'll probably get mad soon enough and go get some hot glue also.
Does Kragen/Pep Boys/AutoZone sell that stuff?
Old May 5, 2003 | 11:45 PM
MySunset350Z's Avatar
MySunset350Z
i've had mine on for over a month......rain....hot weather......freeway driving.
everything is still ok
Old May 6, 2003 | 09:29 AM
ares's Avatar
ares
Veteran
better luck finding hot glue at a fabric store. like hancock fabrics or micheals(sp?). its typicly used to glue fabric. peels off easily... but itll hold good. its really think glue, you just heat it to make it liquid, if you reheated it, it would liquify again. but I think it needs to hit like 200degrees at least to dream of melting.
Old May 6, 2003 | 10:08 AM
teh215's Avatar
teh215
What about Super glue, that should hold alot better than hot glue which can be messy.
Old May 6, 2003 | 02:19 PM
Pat1USMC's Avatar
Pat1USMC
I used a dab of super glue on the ends and in the middle. Its been great since....
Old May 6, 2003 | 04:09 PM
Lee3Z's Avatar
Lee3Z
I have had mine on for 3 months. Usually in the first month it tends to loosen up and start to come off. Just put it back on and after you have done this 2 or 3 times it will finally stay on.
dcains
Sep 21, 2015 09:28 AM
roadmax
Sep 12, 2015 05:55 PM
