Drivers Side Door is stuck Locked shut!!
Old Jul 10, 2007 | 04:34 PM
gNaRKiLL's Avatar
gNaRKiLL
Default Drivers Side Door is stuck Locked shut!!
I dont know what the hell happened but I was out and about today went to the mall and locked my door like normal with the keyless, When I come back I find that I cant unlock the door anymore, it makes the sound but doesnt seem to kick back enough to engage the handles.
Anyone know how the hell I can get the door unlocked? Is there a mechanism that I can slide a coat hanger down in there to try and grab onto? This is damn rediculous, I have to exit via the passenger door!!
Pictures, Ideas etc all welcome. Im kinda stumped here.
Also when I try to use the key it will turn but will hit a point and then I have to force it which causes the whole handle to move out a bit.
Old Jul 10, 2007 | 04:42 PM
drivenCSZ's Avatar
drivenCSZ
so you cant even open the door from the inside?
stein's Avatar
stein
Sounds like something broke inside the door leaving it in the lock position.
Old Jul 10, 2007 | 04:44 PM
gNaRKiLL's Avatar
gNaRKiLL
The thing is totally locked shut
cant open from inside outside nothing, it will lock forward just fine, but wont unlock quite enough i can clearly see a difference in the little lock compared to the passenger side im gonna see if I can take it apart somehow or atleast expose the mechanism.
Old Jul 10, 2007 | 04:46 PM
chima07's Avatar
chima07
hmmmmm, kick it in?
Old Jul 10, 2007 | 04:50 PM
gNaRKiLL's Avatar
gNaRKiLL
So just went out there and messed with it for a sec apparently something is loose because I just slapped the hell out of it and the lock wouldnt budge so I slapped it harder and bam door unlocked.
Old Jul 10, 2007 | 04:53 PM
stein's Avatar
stein
Check this out
Old Jul 10, 2007 | 05:48 PM
gNaRKiLL's Avatar
gNaRKiLL
hey thanks, seems to be working fine for now we'll see I guess.
Old Jul 24, 2007 | 07:54 AM
jtabraham's Avatar
jtabraham
hey, just saw this thread. Same thing happened to me a few months ago. Turns out the linkage popped out of the lock a little, and after a swift hit to the door panel, it fell back into place.
I would recommend that you take off the door panels and make sure all the clips are still in place so that this doesn't happen to you again. In my case, one of my retaining clips had come off which is what caused the problem.
Old Jul 24, 2007 | 10:06 AM
sofa king's Avatar
sofa king
just dukes of hazard it! youll look like a pimp @ the club.
Old Jul 24, 2007 | 10:30 AM
Driven1's Avatar
Driven1
Professional
My door does this sometimes if you either pull the handle to quickly or the lock is not engaged all the way (even though it will still not open. Typically if I re lock the doors and then unlock it again it opens up fine.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
