Air Duct without Cutting into your bumper (Pics)
Old Jul 21, 2007 | 02:17 PM
OneI350's Avatar
OneI350
Default Air Duct without Cutting into your bumper (Pics)
This might be old, if so, I'm sorry, I'm a noob. I used the search and kept hitting the other air duct. I wanted to know if anyone is currently running this airduct. Looks like it would solve a lot of the heat soak issues with pop charger. It may only induct a small amount of cold air into/onto the filter, but I'm mainly concerned about reducing the heatsoak.
does anyone have any before and after temp readings or performace proof?
Is it just 2 bolts for install? Do you have to remove bumper? Is it at all flimsy once installed or does it stay sturdy and in one place?
Any pics with it installed with the bumper on?
Old Jul 21, 2007 | 02:52 PM
Blazemaster's Avatar
Blazemaster
so it looks like it's a duct that extend to the grill? Can't quite tell from that picture. How much does it go for?
Old Jul 21, 2007 | 03:09 PM
JDMZ33's Avatar
JDMZ33
Vendor - Former Vendor
It is from EVO-R.NET Price is $79. I got some installed pics.
http://www.evo-r.net/product/CAI/tube/
Old Jul 21, 2007 | 03:12 PM
OneI350's Avatar
OneI350
post the install pics please
Old Jul 21, 2007 | 03:26 PM
JDMZ33's Avatar
JDMZ33
Another tube for people who have bumper cutted ducts
Old Jul 21, 2007 | 03:29 PM
OneI350's Avatar
OneI350
Old Jul 21, 2007 | 03:38 PM
JDMZ33's Avatar
JDMZ33
Someone did the installed without removeing th bumper on this forum. He said all you need is remove the bottom left plastic part and slip from bottom up. Use original 2 factory screw only.
J.
Old Jul 21, 2007 | 05:37 PM
gsazabi's Avatar
gsazabi
Hmmm very interestd. Will this clear the Amuse Front?
Old Jul 21, 2007 | 06:26 PM
litlechina's Avatar
litlechina
will this really help?
Old Jul 21, 2007 | 06:44 PM
plumpzz's Avatar
plumpzz
Probably at higher speeds. But at low speeds it'd be minimal. I'm sure it'd work a lot better on a vented hood. Nice piece to have regardless...
Old Jul 21, 2007 | 08:19 PM
boma's Avatar
boma
I think the stock configuration works fine. All that air hitting the front opening must also go up into the duct as well.
Old Jul 22, 2007 | 07:41 AM
OneI350's Avatar
OneI350
hopefully we will get someone to chime in that owns one and has done some kind of testing.
Old Jul 22, 2007 | 10:23 AM
MustGoFastR's Avatar
MustGoFastR
^ It's proabbly about as effective as the Varis duct. The Nismo V2 bumper also has one like this built into it. Prob won't get you any real gains, but it can't hurt and will get the coolest, freshest air into the engine.
Old Jul 22, 2007 | 10:30 AM
OneI350's Avatar
OneI350
Minus the hole in the bumper
Old Jul 22, 2007 | 10:36 AM
Chineseguy's Avatar
Chineseguy
couldnt you just make one out of a flexable pipe and be as effective?
Old Jul 22, 2007 | 10:46 AM
MustGoFastR
^ yup; it's kind of ghetto, but it can be done.
Old Jul 22, 2007 | 07:34 PM
Ruthless18x's Avatar
Ruthless18x
I have the K&N intake and it comes with a pipe that runs down that same spot with a wide mouth opening on the end. Can't say it really does much, I hooked up a shop vac on reverse at the bottom and the air flow was decent but you would have to be going at a pretty high speed to get the same effect.
Old Jul 22, 2007 | 07:37 PM
OneI350's Avatar
OneI350
Pics?
phatz33's Avatar
phatz33
wahts the point of purchasing this, it's so easy to make yourself
Old Jul 23, 2007 | 09:22 AM
97supratt's Avatar
97supratt
Hey Jay, any dual ducts for the 07 guys?
