NISMO GT Titanium shift knob pix
Old May 12, 2003 | 08:45 PM
Chebosto's Avatar
Chebosto
chicka chicka!
BoOWNG! Bowng! bowng! Bowng! bowng! Bowng! bowng!
Ooohhh Yeeeaaaahhh..
Old May 13, 2003 | 08:45 AM
ezee's Avatar
ezee
Originally posted by cbsuper
Probably because it acts as a fastener.
Thanks for the insight. Unfortunately there is nothing in the top of the shift lever to fasten to, it's a solid metal shaft.
Old May 13, 2003 | 09:13 AM
john350Z's Avatar
john350Z
Originally posted by ezee
Can you post a picture taken from above? From the pics I've seen it looks like there is a screw that goes through the top. Is there, and if so, why?
ok ezee,
here are the parts:
adapter, screw, and shift ****
screw the adapter on the shifter, put the **** on, and put ther screw in to hold the shift **** in place.
hope this helps
-john
Old May 13, 2003 | 10:43 AM
ezee's Avatar
ezee
Thanks, I've seen that picture. The stock shift **** doesn't require a screw through the top, that's why I'm puzzled. Don't see why this one would need an adapter, seems like it should screw on just like the stock ****, screw it down tight, you're done.
Old May 13, 2003 | 11:23 AM
mdacko's Avatar
mdacko
i like it, but i think it would look better if there was more aluminum trim in the car to match, the **** itself is sweet, but looks sorta out of place in a car with all dark interior.
Old May 13, 2003 | 02:47 PM
cbsuper's Avatar
cbsuper
The reason why you need a screw adapter is because the shift **** does not screw onto the shifter. The adapter gets screwed on, the shifter sits on top, and then you screw the screw in to hold it there. Unfortunately, Nismo had taken the hard route for this, but hey, that's them. You can always get this shifter:
Much cheaper too.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Stevo Z
Oct 3, 2015 09:14 PM
