Clear bulbs, but glows amber.
Old May 15, 2003 | 11:56 AM
Ricky's Avatar
Ricky
Default Clear bulbs, but glows amber.
Hey someone on this website had them in this forum, well I just got them in today, but I can't install them! there isn't enough room to work in there... how do I replace them ? (If the person who orginally made this thread would please respond also)
Here are pics of the area..
Old May 15, 2003 | 12:01 PM
ares's Avatar
ares
Veteran
pull the housing out for access no?
Old May 15, 2003 | 12:20 PM
POWERZ's Avatar
POWERZ
You can't change bulbs from under the hood. Take the fender well out you have easy access.
Old May 15, 2003 | 12:57 PM
dsmal's Avatar
dsmal
Its possible from there, undo the bolt there, you can pull the light forward slightly. But you need to have small hands. Its possible, thats how I replaced mine.
Or you can jack the car up and remove the splash guard -- I believe this is what PowerZ is referring to.
Hope that helps.
Old May 15, 2003 | 01:34 PM
Ricky's Avatar
Ricky
Damn nissan and their tight engine space. Removing the fender is a crap load, have to remove those screwes, then yank fender down, then reach through bottom car, but then again, my hands are too big to just reach into that hole. That corner of plastic is what is blocking my hand.. Maybe I should cut that piece off! haha.. damit.
Old May 15, 2003 | 01:37 PM
POWERZ's Avatar
POWERZ
Wait till you try to replace the bulbs in ther rear bumper. According to the service manual you have to remove the rear bumper which includes drilling/replacing rivets.
Old May 15, 2003 | 01:50 PM
dsmal's Avatar
dsmal
Ricky, put yur car up on stands then remove those plastic splash guards that sit below your headlights, you should have enough room to get it from there.
POWERZ, I tried replacing the reverse bulbs, if you remove the tail lamps, you can reach down and access the bulbs (at least on the passenger side).
Old May 19, 2003 | 05:12 AM
POWERZ's Avatar
POWERZ
dsmal - you're right, you can access the rear combo lights from the tail light opening. I couldn't get to the front signals from the top though and had to remove the fender wells. Check out my lights HERE.
Old May 19, 2003 | 12:37 PM
Ricky's Avatar
Ricky
Default Hints on installing turn signal from engine bay area!
Alright, well after about 40 minutes of playing with the turn signals, finally got them in!
My hand couldn't reach inside there, so this is what I did...
1) Losen the single 10mm bolt, this will give about 3-4mm of more working space (every mm helps)
2) Reach in and take the bulb out.
3) Use something long, I used a screwdriver and poke around gently untill you get the bulb facing up towards you.
4) Reach in and gently get the bulb and pull up, then use your other hand to hold the base of the bulb area, and gently pull the bulb out, make sure to pull it stright up, not sideways!
5) Take your new bulb and hold it by the base of the bulb and gently push it in. Try not to touch the glass, but it shouldn't do anything if you do. You might have to push hard. I shaved my bulb base a tad with a knife to get it in slightly easier.
*** If you use these exact same bulbs, I couldn't get the bulb completely in, but it was in abuot 95%. Didn't hear a click, but I figured it should be okay, so don't worry too much if you can't get it in all the way ***
6) Push bulb back down gently with the screw driver.
Now the tricky part...
7) Using your screw driver and your handle, gently and slowly try to angle the bulb so it will go inside the hole for the turn signal. Try not to let the bulb touch any metal!! This will take about 15 minutes to do so.
8) Once it's in, use your hands to push it in all the way, and twist till it's locked in.
And repeat for 2nd turn signal!
Old May 19, 2003 | 12:40 PM
Ricky's Avatar
Ricky
Forgot the picture! Here, enjoy!
Attached Thumbnails Clear bulbs, but glows amber.-turn-signal-before-after-copy.jpg
Old May 19, 2003 | 02:54 PM
mdacko's Avatar
mdacko
Hey Ricky, what kind of front bulbs are those? (brand, style, size, etc) where'd you buy them at?? thanks
Old May 19, 2003 | 03:40 PM
Ricky's Avatar
Ricky
They are Cycolite (brand), size: 7440 , but I felt it was slightly too large, so I shaved it a little bit with a knife. Style, they are all one style, a glass bulb, and a base.. haha.
I bought mine at http://cgi.ebay.com/ebaymotors/ws/e...&category=33717
Just email him, he has more.
Old May 19, 2003 | 07:17 PM
mdacko's Avatar
mdacko
hey that link doesnt seem to be working right now, can you give me an email address?? thanks
Old May 20, 2003 | 05:33 PM
Ricky's Avatar
Ricky
More pics
Old May 20, 2003 | 05:43 PM
Ricky's Avatar
Ricky
Close up of bulb.
Old May 20, 2003 | 05:44 PM
Ricky's Avatar
Ricky
Bulb at night, with HID on
Hope these pics helped some of you decide if you want to buy them or not.
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
