Nismo V2 ride height?
Old Sep 25, 2007 | 12:59 AM
joekool's Avatar
joekool
Default Nismo V2 ride height?
Hi guys, I'm considering the Nismo V2 Front Bumber and Sides and I was wandering if anyone here knew or could measure how high off the ground the lowest part of the front bumper and side skirts sit off the ground on stock suspension.. The reason I ask is because I'm from Australia and the legislation here is that any part of the vehicle must not be lower than 100mm..
thanks
Old Sep 25, 2007 | 06:55 AM
Watkins's Avatar
Watkins
I can't help you much with the sides, but I can give you some images of the front clearance. These pictures are taken on a smooth concrete surface and vary from the camera placement being on the ground looking up to the camera being in line with the lowest visible portion of the bumper.
The below is from the camera resting on the concrete angled up.
This picture is pretty much as if the camera were the same height as the bottom of the bumper.
The way I look at this is, if you are measuring the bottom lip of the bumper to the ground you are looking at 5" of clearance, if you are measuring the lowest point of the bumper, (which is not visible without being under the car) you are looking at 4.5" of ground clearance. Hope this helps.
Old Sep 25, 2007 | 04:42 PM
joekool's Avatar
joekool
thanks so much watkins, you're a champ m8.. Glad this bumper will be ok here
Old Sep 25, 2007 | 07:53 PM
joekool's Avatar
joekool
watkins, you got any pics of your ride?
CJs_Z33
Sep 18, 2015 12:06 PM
h4lights
Sep 4, 2010 02:45 PM
adanande
May 26, 2004 12:42 PM
Hunter Z
Apr 30, 2004 06:11 PM
Jim Jones
Jan 19, 2004 08:40 PM
