Left foot rest
Old Oct 7, 2007 | 03:45 PM
pplanner's Avatar
pplanner
Default Left foot rest
My wife's 07 Roadster foot rest (to the left of the clutch pedal) came completely off while she was driving and almost caused a crash. I looked at the way it is fixed to the floor board and could not believe how flimsy the installtion is. The four philips screws only attach the aluminum plate to a massive plastic base that is fixed to the floor with plastic (very badly engineered) posts. This is defrinitely a safety issue and should be looked at.
Any one with case experience and a good comment ?
Old Oct 7, 2007 | 04:08 PM
DavesZ#3's Avatar
DavesZ#3
Actually, my experience with it is this - once you remove the dead pedal once or twice, you weaken the plastic pieces that lock it to the metal posts. From that point on, yes it is loose and I suppose you could kick it loose. The bad thing is that you can't buy the replacement plastic locks, you have to buy the whole dead pedal assembly.
Old Oct 7, 2007 | 04:09 PM
blazed54's Avatar
blazed54
My cars foot rest also feels pretty wobbly and i can't remember if it was like that before... if it's not normal i'm gonna have to take it in for warranty work.
Old Oct 7, 2007 | 04:13 PM
black06z's Avatar
black06z
Mine feels fine, and I use it most of the time.
Old Oct 7, 2007 | 05:24 PM
henry j's Avatar
henry j
+1 mine is loose 2 and theres no tightening it.
Old Oct 7, 2007 | 06:57 PM
pplanner's Avatar
pplanner
Well, I think it is definitely a safety issue (after what happened to my wife). and no, she was not wearing high heels or boots; just a pair of loafers. She took her foot off the foot rest to push the clutch in and the whole cheap plastic concoction came off and landed partly behind the pedals, partly under her foot; enough to disorient her for a couple of seconds. It had never come off before.
Old Oct 7, 2007 | 08:42 PM
I removed the foot rest, and polished it with steel wool.
Putting it back together again was OK. I just used a bigger sheet metal screw for the center.
Old Oct 8, 2007 | 04:51 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
the common fix is to use plumbers tape on the posts and then shove it back on. use SEARCH and you will find a thread on this topic with a few solutions.
Old Oct 8, 2007 | 05:01 AM
I1DER's Avatar
I1DER
The more you hide stuff in there, the quicker the threads will wear out.
Old Oct 8, 2007 | 05:21 AM
Spork's Avatar
Spork
No issues here. Mine still feels solid. 2003.
