Tail lamp problem Help please
Old Nov 7, 2007 | 11:09 AM
MannyTG1's Avatar
MannyTG1
Default Tail lamp problem Help please
My problem starts like this: I looked at my plate lights and then one is blinking I took out the whole thing, it turns out to be that some how when I moved it there was a piece of wire. The only thing I saw was a small spark after that my parking, and tail lights didn't work. I checked the fuses they're all good I disconnected the bat and still no working lights. So if theres someone that can help I would really apreciate it, thank you.
Old Nov 7, 2007 | 11:18 AM
zdatsun's Avatar
zdatsun
It's the BCM or better known as the Body Control Module. Nissan will replace it for you for only 232.14......
Old Nov 7, 2007 | 11:23 AM
MannyTG1's Avatar
MannyTG1
Focks man that's a lot! Where is it located?
Old Nov 7, 2007 | 11:24 AM
JasonZ-YA's Avatar
JasonZ-YA
ouch.........do you have anymore info on this little guy? pics, etc?
Old Nov 7, 2007 | 11:38 AM
MannyTG1's Avatar
MannyTG1
No man no pics, sorry. The only thing I know is is that it was the right licence plate light as your facing the rear end of the car. when I moved it, it sparked and after that no more working tail lights. The only way they work is when you press the brake pedal. My parking lights, stereo lights, and brake lights don't work. Is there any other possibility? Thanks
Old Nov 7, 2007 | 12:17 PM
zdatsun's Avatar
zdatsun
Can't help you any further. I went through all the steps of checking all the fuses including the ones next to the battery.
Old Nov 7, 2007 | 04:09 PM
timmays350's Avatar
timmays350
the bcm is located behind the driver side kick panel, has a couple harnesses running into it, can't say for sure whether it was the bcm or what to me it sounds like a fuse, but if you say you checked them ALL. maybe want to go through and double check.
Old Nov 7, 2007 | 08:31 PM
frenzee's Avatar
frenzee
The tail lamp fuses are not next to the battery. They're in that second fuse box "behind" the battery. You have to remove the plastic cover that goes between the battery cover and windshield to get to it. Did you check those?
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
