oem front grill remove?
Old Nov 14, 2007 | 09:10 AM
ofl0926's Avatar
ofl0926
Default oem front grill remove?
hey whats up everyone. i was wondering if anyone has removed the front grill off their oem bumpers. i would think it would give a cleaner look.
oscar
Old Nov 14, 2007 | 09:24 AM
usmanasif's Avatar
usmanasif
You can do it, but a giant hole will look a lot worse than OEM, IMO. It isn't a one piece grill though; each bar is held onto a skeleton structure (frame) behind it with tabs. You could conceivably remove all three on your '04 without taking off the bumper. But then you will need to cut off the frame as well. Making the end result look clean would be a bit tough.
Old Nov 14, 2007 | 09:33 AM
VO...'s Avatar
VO...
Administrator
oscar
It'll look bad unless you have a large oil cooler or inner cooler behind it. Otherwise all you'll see is the chipped up raggedy OEM radiator and power steering pump. -2cents-
Old Nov 14, 2007 | 09:39 AM
ofl0926's Avatar
ofl0926
it was just a thought cause i have seen some front bumpers come with no grill.
maybe with a front lip it might look a little better
Old Nov 14, 2007 | 09:45 AM
VO...'s Avatar
VO...
Administrator
I see what you're saying. Only thing about after market bumpers vs. OEM bumpers, is they give it a new look which takes focus away from the inner workings of the scoop area. A lip would make it look better, but I still stand by my opinion...
Old Nov 14, 2007 | 09:47 AM
pimpin714style's Avatar
pimpin714style
Default dremmel
i cut mine out very carefully, actually remove the whole front bumper and replaced with this one http://www.thezstore.com/page/TZS/PROD/50-1694
Old Nov 14, 2007 | 10:04 AM
z-u-later's Avatar
z-u-later
I removed mine and installed an after-market grill that I had powder-coated black. Looks much cleaner.
Old Nov 14, 2007 | 10:18 AM
ofl0926's Avatar
ofl0926
very understandable. it was just a thought.
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Paul.
Oct 16, 2015 07:34 PM
codek
Sep 28, 2015 03:03 AM
ILoveDrifting
Sep 7, 2015 03:15 PM
