how do you remove the steering wheel?
Old Jun 6, 2003 | 05:18 PM
N74DV's Avatar
N74DV
Default how do you remove the steering wheel?
I'm working on a "paddle" shifter mod for the 5AT.... I need to remove the steering wheel to gain access to the inside.
How is the steering wheel removed? Anyone with a service manual that can post a pic of give directions?
thanks!!
Old Jun 6, 2003 | 06:46 PM
alphared's Avatar
alphared
The whole steering column or just the housing? To remove the housing just unscrew the driver's dash (2 on the bottom and one under the kick panel) once thats off, unscrew 4 screw from the bottom of the column (one is under the adjust arm) Pull the ring thats around the ignition and pull the housing apart.
Old Jun 6, 2003 | 08:32 PM
N74DV's Avatar
N74DV
yeah I did that, but now I need to take off the steering wheel....
Old Jun 6, 2003 | 08:43 PM
dsmal's Avatar
dsmal
Remove airbag...
Then the rest
I hope that helps bro.
Old Jun 6, 2003 | 08:55 PM
N74DV's Avatar
N74DV
thats exactly what I needed.... THX!!!
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
