help installing 06 headlights into 03 350z
Old Jan 10, 2008 | 08:03 PM
Zgrabin's Avatar
Zgrabin
Default help installing 06 headlights into 03 350z
ok well i 'searched' around and couldnt find any info on DIY or related topics to installing 06 headlights into my 03 350z..
so any help info would be appreciated..
and if your gonna just flame,take it somewhere else
Old Jan 10, 2008 | 08:06 PM
yoichi's Avatar
yoichi
Its plug&play....
Old Jan 10, 2008 | 08:16 PM
Zgrabin's Avatar
Zgrabin
Originally Posted by yoichi
Its plug&play....
you sure? i heard theres different wiring needed?
my 03s are HIDs so maybe its a plug&play if youve had hids in the 03s
Old Jan 10, 2008 | 10:59 PM
TayTaythatsme04's Avatar
TayTaythatsme04
ya plug and play but don't forget to cut the turn signal wire or your signals will be permanently on.
T
Old Jan 11, 2008 | 05:29 PM
lebby-pooh's Avatar
lebby-pooh
T
yup ditto. i beleive its the green wire.
Old Jan 11, 2008 | 09:51 PM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
T
Not the actual turn signal will be stuck on, just the parking/Day time lamps will be on all the time.
Old Jan 12, 2008 | 12:53 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
DO NOT CUT THE WIRE ON YOUR HEADLIGHT HARNESS
Cut the wire on the BULB instead. It's because the bulb is $5...your harness is probly priceless and you don't wanna go around cutting harness wires. If you do a bit of search you can find a picture of where on the bulb to cut and which wire.
Old Jan 12, 2008 | 12:55 PM
SuperBlack350z's Avatar
SuperBlack350z
+1
I cut the wires in the turn signal bulbs itself, not the harness. If you need the pic of which wire to cut, PM me.
Old Jan 12, 2008 | 01:00 PM
RED HOT Z's Avatar
RED HOT Z
I didnt cut anything and I see no difference.
Old Jan 17, 2008 | 10:55 AM
Zgrabin's Avatar
Zgrabin
can anyone give me a possible link to a DIY of installing 06 headlights into an 03 Z??
i think i found a thread somewhere before but cant seem to find it now..
Old Jan 17, 2008 | 10:57 AM
SuperBlack350z
Installation is the same if you didn't have 06 headlights.
Old Jan 17, 2008 | 11:00 AM
Zgrabin's Avatar
Zgrabin
o alrite cool thanks..so its got the same bolting areas and what not??
Old Jan 17, 2008 | 11:39 AM
InZomniac's Avatar
InZomniac
HAHAHA You bought Freddy's busted *** headlights.
Old Jan 17, 2008 | 10:24 PM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
better than buying a busted *** red head
m_0g
Jun 3, 2021 10:05 AM
