Wind noise break in
hey, I currently discover a problem. If I drive highway speed I get an annoying wind noise from the driver side. I already took it to the shop, they changed the door seal but it still does it. If it does it and I pull the switch the window goes a little up and the noise stops for a few seconds any ideas or fixing solutions ?!
The z in general has alot of noise. I think I know what you are talking about though.
When I had window motor problems, the driver side window will no longer automaticly roll up/down when you open/close the door. I noticed that once I window motor stop doing this, I had a louder wind noise from the window.
How to fix it? I assume that your window rolls down after it goes up. Does your window still work properly?
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
