FairladyZ emblem - removing 350z embem - HELP
Old Jun 16, 2003 | 12:25 PM
travelmadness's Avatar
travelmadness
Default FairladyZ emblem - removing 350z embem - HELP
Definitely want to get rid of my 350z emblem... are there holes behind that one? (Not the center rear emblem, but the 350z emblem that is off to the side) Also, any thoughts on the fairladyz emblem--- if there are holes, will that emblem fit into the same holes. Thanks!!
(sorry if this has been discussed before, couldn't find info in my search i did)
Old Jun 16, 2003 | 12:38 PM
jimster716's Avatar
jimster716
no holes...just take fishing line to remove the emblem and clean up the surface of the adhesive.
Old Jun 16, 2003 | 01:27 PM
jackwhale's Avatar
jackwhale
I used dental floss, worked the same. Easy to remove. cleaned up the adhesive and it looks great.
Old Jun 17, 2003 | 12:20 PM
Vlad's Avatar
Vlad
what about NISSAN badge in the back? Anybody removed it? Any holes bihind it?
Old Jun 17, 2003 | 12:24 PM
jackwhale's Avatar
jackwhale
I saw a picture on a previous post that showed two small holes under the center Nissan emblem.
Old Jun 18, 2003 | 10:31 AM
travelmadness
Default got my emblem off
i got my emblem off with dental floss... anyone know tricks for getting all the adhesive off ? i got most of it off, but there is still a bit left ??
Old Jun 18, 2003 | 11:30 AM
jackwhale's Avatar
jackwhale
I used 3M general purpose adhesive cleaner which I bought at an auto supply store.
Old Jun 18, 2003 | 01:39 PM
travelmadness
thanks for the tip -- i just dont want to use anything abrasive enough to strip any clearcoat etc.
Old Jun 18, 2003 | 01:51 PM
jackwhale's Avatar
jackwhale
I used the 3M adhesive remover because it is recommended for cars. There was no problem with paint being damaged. I just waxed the trunk lid, and there is no sign of where the 350Z emblem had been.
I like the 'shaved' look, and I would remove all of the outside emblems if they were just glued on. Unfortunately I think that the rest are held on with clips.
Old Jun 19, 2003 | 10:47 AM
travelmadness
Default got off the adhesive
i used "goof off" - it worked really well. it all came off pretty much instantly. i waxed the area around the emblem afterwards, because i bet those adhesive removers strip off the wax also. its amazing how much better i like the look from the back without that emblem. (and its amazing how cheap the emblem feels once you get it off the car!)
Siqcology
Sep 18, 2019 01:45 PM
reno56
Interior
17
Nov 20, 2015 05:21 PM
hardkicks
Sep 20, 2015 12:28 PM
RWDBajan
Sep 17, 2015 04:52 PM
