TS diffuser owners (help needed)
Old Feb 4, 2008 | 08:38 AM
djtimodj's Avatar
djtimodj
Default TS diffuser owners (help needed)
Guys i have the 5zigen pro racer zz spec exhaust and realy want to fit the ts diffuser. just need some help on if you lot think it will fit with my exhaust.
few pics i have been looking at trying to decide.
https://my350z.com/forum/body-interior-exterior-and-lighting-diy/322444-diy-ts-rear-diffuser-installation-instructions.html
Few pics of my zorst for you to get an idea ?
http://forums.350zukownersclub.com//...opic=17012&hl=
Thanks guys.
Old Feb 4, 2008 | 08:47 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
I'm not sure because of the design you might just have to try it out and hope for the best. Honestly I think you should ditch that exhaust. It's like a hybrid, it's not a normal single and it's not a dual tip nor a true dual...such an odd design.
Old Feb 4, 2008 | 09:36 AM
MaRbLe's Avatar
MaRbLe
Im running a Powerhouse Amuse exhaust and I had to cut the diffuser for it to fit...
Old Feb 4, 2008 | 01:23 PM
djtimodj's Avatar
djtimodj
Any pics mate??
Did the cuts go ok ?? any fraying of the cf??
Old Feb 4, 2008 | 01:24 PM
djtimodj's Avatar
djtimodj
Alvin that is not the exhaust i have. Mine is the ZZspec. Twin rear cans.
Check out my pics in the link.
Old Feb 4, 2008 | 05:36 PM
MaRbLe's Avatar
MaRbLe
Originally Posted by djtimodj
Any pics mate??
I will have to get some pics. Had to cut a bit from the front to clear a pipe, then had a body shop use a router (sp?) to cut a bit of the carbon where the tips are. The carbon that goes under the tip was cut in that case. I didnt have a fraying issue when I cut it. I used a dremil at high speed and it kind melted where you cut if that makes sense.
Old Feb 5, 2008 | 06:20 AM
THE TECH's Avatar
THE TECH
Most exhausts will require the diffuser to be modified.
Old Feb 5, 2008 | 06:42 AM
djtimodj's Avatar
djtimodj
Im not worried about moding the back side of the diffuser im just not sure if it has enough clearance from the bottom of the bumper to the top of the diffuser? If you see what i mean? My exhaust as it has twin cans sits quite low.
Old Feb 5, 2008 | 07:07 AM
THE TECH's Avatar
THE TECH
I kinda understand what you're saying. Unfortunately, there isn't much of a way to find out unless someone with that particular exhaust has already tried installing one before.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
dcains
Nov 11, 2015 11:36 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
