Rattle from passenger side.. need help.
Old Feb 10, 2008 | 10:52 PM
maXmood's Avatar
maXmood
Under Boost!
Default Rattle from passenger side.. need help.
hey guys,
just like the rest of us, we are all facing this frustrating rattle.. mine is a bit different, and i've searched most if not all of the threads with rattle issues, but none discribed the same problem..
while driving, i step on the gas to reach around 4200 rpm it gives a rattle sound on the passenger side, and it sounds like a metal on metal or glass on metal. i parked the car, step on the gas to get the rpm on 4200 again, but it doesn't show, i then increased it to 5500 rpm and it started again..
so, since i'm on the driver's seat, i cannot tell exactly from where the sound is coming. so i asked my bro to hop in to the passenger seat to try and check out the sound source.. i step on the gas to reach 5500 again, but there is no sound~~~!!! i asked him to get out, and i get step on it to reach 5500 and it's there!!
so i thought, probably his weight is affecting the sound from showing. so i asked him to open the door wide and try to hear from where the sound is coming.. again i reach 5500 and no sound!! , so i took him for a ride to check the 4200rpm again, and no SOUND!!!!!...
now he started thinking i'm hearing things!!! so i asked him to get into the driver's seat and try it himself. and he did and he was shocked ...
so i parked and checked again, step it to 5500 and the sound showed, while keeping that on 5500, i pull my arm and tried to press on the door/door panel and glass, but it doesn't seems to stop the sound from coming..
i'm a bit pissed with this sound, i don't want to take it to the dealer yet, cuz i know that they'll keep it for 4 days at least to try and figure it out, and i can't afford that cuz i don't have a 2nd car..
what do you think guys?? how can i go on about checking the problem?
thanks
Old Feb 11, 2008 | 11:22 PM
maXmood's Avatar
maXmood
Under Boost!
B.U.M.P ...
anyone?
Old Feb 11, 2008 | 11:27 PM
r_seng's Avatar
r_seng
hell i have rattles in various places after i got my springs in, harder ride tends to move things around.
gl finding the source.
Old Feb 12, 2008 | 08:07 PM
agentzeros's Avatar
agentzeros
I have an occasional rattle on the passenger side also. At first I thought I had blown one of my speakers. Because it does sound like a little peice of metal vibrating on another piece of metal. But I turned off my radio and it still was there. I also took everything out of the storage compartment behind the passenger seat. I have noticed that the sound appears when I'm doing around 70 or 80 mph. I haven't heard it in while (knock on wood). If you figure it out let me know.
Old Feb 13, 2008 | 12:16 PM
Fernando Vidal's Avatar
Fernando Vidal
See if this helps:
https://my350z.com/forum/showpost.ph...7&postcount=35
Old Feb 13, 2008 | 12:37 PM
skwid's Avatar
skwid
I had an issue with mine rattling a while back. I took the lower panel off of the dash on the passenger side and adjusted that knee plate or whatever that thing is. That's what was causing mine.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Rev_Night
Nov 7, 2020 06:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
samansharif
Sep 25, 2015 12:31 PM
