Painting the Z Tube... Help?
Old Feb 18, 2008 | 07:37 AM
Xzero's Avatar
Xzero
Default Painting the Z Tube... Help?
Hi everyone
Well, I'm gonna try what the title says, paint my z tube. But there's one problem, I dont know what to do. I'm a total space case when it comes to painting so if any one can point me in a good direction & give me some info (Materials? Prep work? Sanding? High heat paint? High heat clear coat?), it would be appreciated. I have no shop, so this will be a garage project, no spray gun (Might buy one to do the engine cover,worth it? Or can I just spray-bomb it?), so a "tool list" would be nice.
Thanks for your time!
Old Feb 18, 2008 | 08:22 AM
Rowlett's Avatar
Rowlett
Bump
Intresting
Old Feb 18, 2008 | 08:41 AM
phreaktor's Avatar
phreaktor
Design Engineer
I would wet scuff it with 800 then 1000, prime it, and use a spray meant for plastics.
Old Feb 18, 2008 | 09:05 AM
sintaxeror's Avatar
sintaxeror
sorry I'm a noob.. what is the Z tube?
Old Feb 18, 2008 | 09:17 AM
tropicalypso's Avatar
tropicalypso
Its the tube that comes after the Y tube.
(it runs from your air intake box/filter to your intake plenum... its the long black tube on the top of your engine)
Old Feb 18, 2008 | 12:10 PM
03Zilverstone's Avatar
03Zilverstone
Sand it down with some 600 and clean it up real good. Spray a few light coats of adhesion promoter about 5-8 minutes before spraying your base. Wait 10-15 minutes between base coats until it's uniformly painted. Wait 20-25 minutes and spray a light coat of clear. 12-15 minutes and spray a medium-wet coat of clear. 20 minutes and another medium-wet coat of clear.
For something like that you'll be fine to go with rattle can.
Old Feb 18, 2008 | 08:54 PM
Rowlett's Avatar
Rowlett
Old Feb 19, 2008 | 06:50 AM
Xzero's Avatar
Xzero
Thank you everyone for your input! I'm going to attempt this with an extra z tube as soon as it arrives. I'll post some pics of it within the next couple of weeks hopefully...
Rev_Night
Nov 7, 2020 06:00 PM
350Z_Al
Oct 29, 2020 07:44 PM
Cashwin
Oct 1, 2015 06:36 AM
