I used vice grips on the lever and towel and big *** crescent wrench on the base of the ****. It was a pain but it came off fine with a ton of effort. No damage at all.
Exactly what i did but the funny part is: seems like it wouldn't come loose as i'm turning it to the left so i turned it back to the right (couple times) then turn it left and right then....boom it's off.
I know when I had my 03 the silver shift rod was completely exposed; but when I got my 05, the shifter was a lot fatter under the boot and had a rubber 'collar' on it. I had to take vice grips and lock it onto the collared shaft and then twist the **** with channel locks. It tore up the rubber collar thing a little, but the vice grips were tight enough that the shaft did not move.
Moral: I don't think you can hold the shifter **** tight enough with just hand strength....you need vice grips.
