removal of rear turn signals
Old Jul 2, 2003 | 10:25 PM
mgl's Avatar
mgl
Question removal of rear turn signals
does anyone know how to remove the rear turn signals?? i think the removal of the rear bumper is needed, but i do not know how. any help will be appreciated.
Old Jul 3, 2003 | 05:19 AM
POWERZ's Avatar
POWERZ
If you are just changing bulbs it's a lot easier to pull the tail lights and reach them from the top. Tail lights pop off after removing 3x10mm bolts on each light. Are you changing to a silver bulb or leds maybe?
Old Jul 3, 2003 | 05:35 PM
mgl's Avatar
mgl
i will be changing the bulbs. but i need to remove the entire turn signal so i can smoke 'em out first.
Old Jul 3, 2003 | 09:38 PM
mgl's Avatar
mgl
no one knows how to remove the rear turn signals or the rear bumper??????????
Old Jul 3, 2003 | 09:46 PM
ares's Avatar
ares
Veteran
its complicated actually, I removed mine...
there are 2 flaps on the bottom, they face up, between the bumper and the muffler, gotta take those 2 screws out.
then there are 2 or 3 in the tirewell, and bottom corners.
next you have to remove the tail lights, this exposes another bolt or 2 that has to come out, and these PITA white things that have to be twisted, but even with almost any tool I could want, I could not turn them, and since I was replacing the bumper, I actually had to tear the bumper to get the leverage I needed. I couldnt retwist these when I reinstalled the new bumper, luckily I did not really see any purpose to these.
then you just have a series of clips that you have to be careful with, as well as unplugging the trunk pop and combo lights before you can pull the bumper away.
all in all a pretty difficult job, and I had the shop manual, thats the only way to know where all the bolts are.
Old Jul 3, 2003 | 11:07 PM
mgl's Avatar
mgl
ares,
is there any way to remove the rear turn signals without removing the bumper? also, is it possible for you to send me a copy of that shop manual so there are diagrams that i can refer to. thanks.
Old Jul 4, 2003 | 07:41 AM
ares's Avatar
ares
Veteran
here ya go
Old Jul 4, 2003 | 08:10 AM
voodoo's Avatar
voodoo
Question
hi, where can i get a copy of the manual?
Old Jul 4, 2003 | 11:30 AM
ares's Avatar
ares
Veteran
nissan sells it, but its pricy, like 200$ or somethin
Old Jul 4, 2003 | 04:23 PM
dougrace zs's Avatar
dougrace zs
VandyZ says: You can get to the rear turn signals by removing the rear tail lights. There are 3 bolts and 2-3 snap in's. Once removed you can reach the rear turn signal bulbs.
Old Jul 4, 2003 | 09:15 PM
ares's Avatar
ares
Veteran
yeah you can definitly do it, wont be easy, but definitly less invasive than removing the bumper.
taking off the tail lights is childs play, 3 easy to access 10mm bolts, and 2 clips, just pull out towards the side of the car to disengage the clips.
Old Jul 4, 2003 | 10:34 PM
mgl's Avatar
mgl
thanks. i will try to remove the bumper sometime soon. i have to remove the rear turn signals so i can smoke 'em out.
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
