Easy way to kill the Daytime Running Lights or make your HIDs DRL instead?
Old Apr 9, 2008 | 02:01 PM
gregom's Avatar
gregom
Default Easy way to kill the Daytime Running Lights or make your HIDs DRL instead?
My 04.5 ZR has these stupid little DRL's that just looks really weird when my HID's are on. Is there a fuse or something simple I can just pull to get rid of them? I'd rather just use my HID's are DRL's, I turn them on in day anyway...
Old Apr 9, 2008 | 02:15 PM
lovemysilverZ's Avatar
lovemysilverZ
Are these lights on when the light switch is in the "off" position or are they on when you turn one click? because i think u might be referring to the city lights down where the hi beams reflect??? these lights are on when turn the first click and then the second click is to turn the lights "on"...
Iv never herd of z's having DRL's but to get rid of that light just simply pull it out. Its a fairly small little bulb...
Old Apr 9, 2008 | 03:19 PM
stylett9's Avatar
stylett9
i wouldn't use your headlights as day time running lights. HID's are expensive to replace.
if you want day to running lights then go buy some fog lights and put them in your grill. This is what i'm considering doing.
Old Apr 9, 2008 | 06:00 PM
gregom's Avatar
gregom
Yeah I guess it is a 'city light'. Thought it was a DRL from the looks of it. But yeah, a small little bulb. Is it easy to take out? Looks like i'd have to take the entire headlamp out which i'd rather not do until I replace my HIDs anyway.
And I don't have a problem replacing HID capsules, they are only $140 or so for a pair which isn't that much. They last at least 2 years or more with how much I use them.
Anyway, i'm assuming this 'city light' isn't on its own fuse, so I'd have to take the bulb out?
Old Apr 9, 2008 | 06:34 PM
lovemysilverZ
yea man its pretty simple, no need to take the headlight out. just lift your car on a little floor jack (either side) and remove a few pop-pins and pull the mud shroud out and BAM its right there, just twist and pull.
Old Apr 9, 2008 | 06:52 PM
usmanasif's Avatar
usmanasif
Err...that's just your humble parking light. DRLs are lights that run continuously, regardless of whether headlights are on. Thank goodness only Canadians are stuck with those
Just remove the bulb and be done with it.
Old Apr 9, 2008 | 07:00 PM
blackfairlady's Avatar
blackfairlady
I actually have been considering trying to make my signals double as auburn daytime running lights. (Think general motors vehicles such as the previous generation cts.) Does anyone know what this would entail?
Old Apr 9, 2008 | 08:18 PM
ladyzed's Avatar
ladyzed
I'm replacing those (parking lights) with bright LED's.
Old Apr 9, 2008 | 10:29 PM
terrasmak's Avatar
Already done that and it looks great
Attached Thumbnails Easy way to kill the Daytime Running Lights or make your HIDs DRL instead?-lights.jpg   Easy way to kill the Daytime Running Lights or make your HIDs DRL instead?-lights-2.jpg
Old Apr 10, 2008 | 12:50 AM
itsjoshufocker's Avatar
itsjoshufocker
usually, the heat of the HIDs will really kill the life of those LEDs... ive been trying to look for LEDs or bulbs that can match the HID that can take that sort of heat but no luck...
Old Apr 10, 2008 | 06:57 AM
BlackoutBeds's Avatar
BlackoutBeds
were can you get those led parking lights?
Old Apr 10, 2008 | 07:52 AM
gregom's Avatar
gregom
Thanks fellas i'll probably remove it this weekend.
Old Apr 10, 2008 | 10:21 PM
terrasmak's Avatar
I bought mine at Pep Boys, and have been running them for a year now. No heat related problems.
350z_z33.
Jul 3, 2017 04:01 AM
seagrasser
Oct 11, 2015 03:27 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
sccarally
Meet-Ups / Events (Texas)
Sep 27, 2015 01:06 PM
