Quick question for body kit gurus
Old Apr 12, 2008 | 08:23 PM
NoahzBurnt's Avatar
NoahzBurnt
Default Quick question for body kit gurus
My sides are urethane overlays...after time the double sided tape starts sucking and the center of the skirts starts falling off and looks like hellen keller did my install.
Is there any tape that holds really well? I would glue or mould them but for some reason I damage and repiant my sides once a year at least yea so I would still need them semi-removeable
Old Apr 13, 2008 | 03:25 AM
german_tuning's Avatar
german_tuning
every tape is ****!
Use some body-glue that will fix it for the next 50years!
If you do it well you wont have to paint it again!
If you have a fax I will fax you the mounting instruction of my skirts, i didn't have to paint it after using the glue!
Old Apr 13, 2008 | 04:20 AM
phreaktor's Avatar
phreaktor
Design Engineer
Gorilla Snot ftw
Old Apr 13, 2008 | 06:53 AM
Moroccan_Mole's Avatar
Moroccan_Mole
can you use rivets?
Old Apr 13, 2008 | 07:08 AM
Zridder19's Avatar
Zridder19
I used 2 screws inside the door jam, and the 3 factory push pins on the side. We also made a elbow bracket under the car using the stock screw location. it holds the skirt very still.
Old Apr 13, 2008 | 07:53 AM
haeshik's Avatar
haeshik
with all that it better hold the skirt still
Old Apr 13, 2008 | 08:14 AM
Mapleleaf's Avatar
Mapleleaf
Use what the Glass Shops use for the Windows .. Urethane
Old Apr 13, 2008 | 08:56 AM
JRYAN350Z's Avatar
JRYAN350Z
3M makes a double sided tape that is thin as hell and holds like no other.. It is actually used in the airline field for panel repair..Either hit up the web site or you can get it from a place called FASTENAL.
Old Apr 13, 2008 | 06:37 PM
NoahzBurnt's Avatar
NoahzBurnt
see my sides are uretane overlays....they also do NOT have any area under the door on the inside as seen here:
i took them off and sanded down all of the old glue on the stock sides and the wings west ones. I cleaned and degreased. I reattached the stock sides so that fit perfect again. I am going to give a few of these options some serious consideration...I am also contemplating using adhesion promoter and some 3M tape and then run a bead of color matched silicone along the top edge to add strenth and make them look moulded.
Old Apr 13, 2008 | 06:43 PM
NoahzBurnt's Avatar
NoahzBurnt
German Tuning: if you can fax them to me that would be awesome...i'll PM you the #
JRyan: If you can shoot me a link to the exact product you are describing i would def. owe you one bro!
JjL
East Canada
Jun 12, 2019 03:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
Obeorangekenobi
Sep 11, 2015 07:17 AM
NYGiants0186
Sep 8, 2015 10:37 AM
