Aerosync Bumper Problem
Old Apr 17, 2008 | 08:20 PM
Youngz's Avatar
Youngz
Default Aerosync Bumper Problem
After mounting this Aerosync bumper the fitment is just off. The front where it attaches closest to the middle there are two dimples in the top part of the bumper. I am not too good with fabricating things to make this work but was wondering if anyone else with this bumper had this issue or anyone has any advice on fixing it. This is a pic that I think you can see where it looks off.....
I will take more soon. Been driving me crazy.
Old Apr 17, 2008 | 09:15 PM
I am with Z's Avatar
I am with Z
UGHH, THE PICTURE IS NOT CLEAR ENOUGH EITHER WAY one of my favorite front bumpers.
Old Apr 17, 2008 | 09:20 PM
Youngz's Avatar
Youngz
I know its not the best. I will take a new one tomorrow to really show the issue. I finally got a few days off and I am trying to see how I can get this worked out....
Old Apr 17, 2008 | 09:21 PM
invazn's Avatar
invazn
did you ask the body shop?
Old Apr 17, 2008 | 09:26 PM
Spork's Avatar
Spork
Looks fine to me
Old Apr 17, 2008 | 09:30 PM
PrevWon's Avatar
PrevWon
Originally Posted by Silverstone-Z
Looks fine to me
+1
Not a fan of the bumper, looking to trade mine for stock...
Old Apr 17, 2008 | 09:38 PM
Youngz's Avatar
Youngz
My stock one is all sorts of jacked up. Love bugs ate it all up. Just sitting in my garage taking up space. I tried putting it on with my intercooler on there now and it looks weird. I like the aerosync but wish I could just get the fitment a little better. 2'' ground clearance is a bit rough too....
Old Apr 24, 2008 | 11:47 AM
mestisoZ's Avatar
mestisoZ
toggle bolts with washers. just push the side in where you want it and screw the toggle bolts on should only need 1 for each side. the aerosyncs usually fit well
Old Apr 24, 2008 | 01:02 PM
Da K00l Aid Man's Avatar
Da K00l Aid Man
Mine has the same issue. It doesn't fit properly under the headlights and there is a sag in the middle of the bumper Thats what I get for going cheap though.
Old May 5, 2008 | 10:20 AM
z350boy's Avatar
z350boy
My body shop was able to install my Aerosync bumper dead on. The headlight area & the middle WILL sag if not adjusted. The 6 holes on the top of the bumper that attach to the radiator support need to adjusted slightly. My shop drilled new holes and used shims to attach. Hope this helps.
Old May 5, 2008 | 11:19 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yep - the bumper is urethane, and has "pull" to it. You can shift the mounting points slightly which will allow the bumper to be pulled more tought, so there is no sag, etc.
Old May 5, 2008 | 11:25 AM
bsomthin's Avatar
bsomthin
yeaah the body shop that put mine on did it perfectly
Old May 5, 2008 | 01:02 PM
Everybodywildou's Avatar
Everybodywildou
I have a dip in the midde of mine. Its kinda noticeable. My friends makes joke and ask "when did get a hood scoop?"
Old May 5, 2008 | 03:03 PM
Youngz's Avatar
Youngz
My bumper is messed up bc the aluminum bumper is no longer behind it to hold it up. The 5'' intercooler doesnt allow me to mount it. Sooooooo i suppose it will stay a little droopy until i figure out a solution....
Old May 6, 2008 | 11:17 PM
live2themaxuk's Avatar
live2themaxuk
Have you go any more pics of this problem, and what you can do to recify it? I have an Aerosync goign on soon, i have the bumper, holes are undrilled and its ready to prime. Would be great to make sure i can get it right
Jamie
Old May 7, 2008 | 07:07 AM
Z1 Performance
Former Sponsor
Jamie
jamie - like anything else it's all in the installation. If the body shop takes the time to do it right, it will fit perfectly.
Old May 7, 2008 | 03:36 PM
TimeAttkZ's Avatar
TimeAttkZ
My aerosync has the same problem. 2 dimples right where the top middle of the bumper meets the hood. It bothers me soooo much
Old May 8, 2008 | 10:12 AM
live2themaxuk
OK great well i will bear that in mind and mention to them prior to fitment about it.
I notice there are like some template 'marks' on where to drill the holes in the bumper, though i assume these are only rough guides and should not be used ?
J
Old May 8, 2008 | 10:15 AM
Z1 Performance
Former Sponsor
best bet is to test fit and mark where you need to make the exact holes - you'll find the indentations are the general area where the holes need to be made, and you might want to make them an oval shape to allow you to shift the bumper as needed for the tighest fit, and then tighten everything down.
Old May 8, 2008 | 10:19 AM
Jay'Z's Avatar
Jay'Z
I found out the hard way all the template holes suck *****.. The fitment was off.. It is a ***** to get right..
