How to take apart 06+ bumper reflectors...?
Like the topic says.. I've got an LED project for the front bumper reflectors -- but every now and again someone mentions what a PITA they are to open up...
I ordered a set recently and I would like to be prepared.
So far all I was able to dig up was an old thread by boogiemyke which mentions something about adhesive solvents and razer blades.. Does anyone have experience with this?
Originally Posted by usmanasif
I took mine apart with a Dremel last winter since they didn't want to budge otherwise.
Did you just use the regular heavy-duty cutoff wheel?
Any trouble sealing them back up?
Anything else you think might be important?
Originally Posted by gothchick
Take the fender liner out. Then they are easy to get to. Only two bolts and a couple of tabs hold them in.
Originally Posted by sintaxeror
Any pics of the in-progress or finished product?
No issues with resealing them. I used the 'Seal All' brand clear silicone. Yes, the regular wheel will be fine, just maintain a steady hand. You wouldn't want so much plastic to come off around the edge that the reflector body becomes 'shorter' so to speak when put back together.
The only other caution I would offer is ensuring you use a new or newly-sharpened drill bit to drill holes into the reflector itself (if that's your plan). That back piece that runs the length of the reflector (where I installed my LEDs) is very fragile and will break easily if you aren't super careful and put even a little too much weight onto it to compensate for a duller bit.
Well.. I tried boogiemyke's razer and adhesive remover method, and I ended up cracking the lens =/
Guess I will have to order a new set and just go dremel..
Originally Posted by GeturZZZs
put em in the oven i think the temp is like 350 thats how we did head lights on my old accord put em in for a few mins then a jus pry apart carefully than ju reseal when done>
Originally Posted by Sick Z
^Yo Ed! did you get those brembos installed? If not, sell them to me plz!
