Lets play a little game....Name that connector!
Old May 19, 2008 | 02:17 PM
SinisterSntra91's Avatar
SinisterSntra91
Default Lets play a little game....Name that connector!
Ok guys I am swapping a VQ35DE into my 240sx, instead of doing a standalone computer I am doing the cheaper yet more challenging route and using full 350z underdash wiring to do the trick. I can only figure out so much by staring at factory service manuals. So I figured I would run these connectors by you guys and maybe I can make identifying these connectors easier on myself, Ill start with the one I cant locate in the manual, this is off the BCM harness of a 07 350z...
Ok lets see how well you know your Z, if you can, name that connector!
Old May 19, 2008 | 03:17 PM
Spork's Avatar
Spork
That looks like the connector that connects the door wiring harness to the main harness.
Old May 19, 2008 | 03:33 PM
haeshik's Avatar
haeshik
i lose
Old May 19, 2008 | 03:36 PM
gambino's Avatar
gambino
If you are putting a DE in, will 07 harnesses be of any use?
Old May 19, 2008 | 03:44 PM
Spork's Avatar
Spork
Good point. The DE most likely has a different ECU layout.
Old May 19, 2008 | 07:31 PM
SinisterSntra91
This is the BCM harness, the DE should only have a different engine harness not BCM harness. And its not the bcm to door harness connector I know that for sure. Its located near the ECM connector.
Pleask
Dec 21, 2021 03:17 PM
m_0g
Jun 3, 2021 10:05 AM
Vigman
Nov 17, 2015 04:34 AM
NissanZcrazy
Nov 2, 2015 06:03 PM
JasonZ-YA
Sep 15, 2015 07:19 PM
