Nismo Wing Added Weight ,,hatch Problems
I Just Put Nismo Fake *** Fiiberglass Wing From Andysautoparts And The Weight Of Wing Will Not Let My Hatch Stay Up,keeps Droping!!!!i Just Got Two New Shocks From Dealer And Still Wont Stay Up!do They Sell Aftermarket Shocks That Are Stronger?if So Where Can I Get Them?apreciate Any Suggestions
There are upgraded ones designed for Zs with spoilers.
These are the heavy duty ones: http://www.thenismoshop.com/ikorb.ph...product_id=448
Another option.
https://my350z.com/forum/body-exterior/251518-fs-heavy-duty-hatch-struts.html
Sells them through Z1.
https://my350z.com/forum/body-exterior/327800-the-cure-for-droopage.html
I've got them with a CF N1 wing and they work well.
wow I had no idea this would happen and that it would be so common. I was thinking of a spoiler but stuck to the wingless stance. Glad I stuck with it cause I would of had a headache.
Originally Posted by gmic
COOL THANKS..YOU THINK THEY WILL JUST SNAP IN AND BOLT ON TO ORIGINAL BALL LOOKING THING,HA!whatever you know what i mean?
~Brad
Originally Posted by brad568
Just so you know, Gmic, these guys are referring to capital letter usage when they use the word "loud." Anytime you use capital letters in an electronic medium you are considered to be yelling, hence the reference to your decibels. Just thought I'd let you know so you knew what was going on. It's fine to capitalize letters at the beginning of sentences and proper nouns, but rude to do so in all words or all letters. Just .02. If you are angry, though, capitalize away ;o)
~Brad
~Brad
Originally Posted by TreeFiddyZee
Another option.
https://my350z.com/forum/showthread.php?t=251518
https://my350z.com/forum/showthread.php?t=327800
I have bought the ones from z1 couple months ago.. they are strong enough to hold on to any aftermarket spoiler.... I got a bad set of ball socket holder (i am waiting on the replacement in mail) but the sponsor "Z1 Performance" and vendor "jtabraham" stands by their products and provide excellent communications...so, I would def recommend you to buy that set for $153 ... $280 for the Nismo set seems a bit overpriced.... hope this helps
Originally Posted by Chebosto
Did u remove the OEM hatch weight?
Hmmmm......good information as my hatch won't stay open and it's a PITA
However, I think removing the hatch mass will decrease your NV performance because that's normally the reason for adding it. Just an FYI
Don't bother with taking the weight out of the hatch..it doesn't help. I have the ones from jtabraham and they are excellent. Nismo ones are way over priced. I have the Nismo wing and with the jtabraham ones, I haven't got hit in the head once plus its an easy install with 2 guys(1 to hold the hatch)
what is NV performance?
that mass is there so the hatch doesnt pop up as fast. it being so far back on the hatch will require even more force to prop the hatch up. every little bit of weight off will help stock hatch shocks, unless yours are blown-
i never had a problem on my stock hatch, stock hatch shocks and my gt wing after i removed the weight.
