***** a/c!
Old Jun 1, 2008 | 04:25 PM
steppinrazor's Avatar
steppinrazor
Default ***** a/c!
alright.. so i take perfect care of my car, its washed once a week, the inside is taken care of really well, never any garbage, its cleaned regularly etc. well my car smells fine... until i turn on my a/c.. and then it smells like ****.. why the f*ck is that? any idea on how i can make that go away? this is a recent problem that started right as it started getting hot here in az.. in case that helps for some reason
Old Jun 1, 2008 | 05:08 PM
Concave's Avatar
Concave
i think i found that turning off the AC a bit before turning off the car helps it not to smell when i turn on the car next time.
Old Jun 1, 2008 | 06:25 PM
henry j's Avatar
henry j
it smells like a wet rag rite? i think i have the same problem some times
Old Jun 1, 2008 | 06:42 PM
BlueZ33's Avatar
BlueZ33
the reason for it smelling musty is when you run your ac it creates moisture in the vents and when it dries it makes that smell when you turn the ac back on, so right before you get to your destination turn your ac to heat to dry out the vents and it shouldnt smell anymore.
Old Jun 1, 2008 | 06:48 PM
CSF's Avatar
CSF
is it a moldy/mildew smell?
i read that lysol sprayed into the vents with the ac on full blast gets rid of the smell for a little while. or turning off the ac for the last 5 minutes when you are driving the car so that the ac condensation evaporates before you turn the car off.
Old Jun 1, 2008 | 07:16 PM
SuperBlack350z's Avatar
SuperBlack350z
i bought an ionizer machine for local details i do. What i do is run it in the car for a hour with no ac then run it for an hour with the AC running. Works great. You can get the machine for 200,
Old Jun 1, 2008 | 10:49 PM
ekidd's Avatar
ekidd
replace the cabin filter??
Old Jun 1, 2008 | 11:10 PM
steppinrazor
yeah exactly like that
Old Jun 1, 2008 | 11:12 PM
steppinrazor
i didnt even think about turning off the a/c.. im going to try that out for a while, thanks for the suggestions
Old Jun 2, 2008 | 03:02 AM
DavesZ#3's Avatar
DavesZ#3
350Z doesn't have one.
Old Jun 2, 2008 | 03:06 AM
DavesZ#3's Avatar
DavesZ#3
When the car is parked and the A/C is on, are you seeing water dripping from the front right side of the car? That should be the drain from the evaporator. If you see little or nothing draining, it could be clogged. That would leave water in the evap unit which could get a buildup of mold/mildew or stale water causing the smell in the car.
Old Jun 2, 2008 | 04:39 AM
Z04's Avatar
Z04
you're joking right?
+1
Old Jun 2, 2008 | 08:45 AM
z350boy's Avatar
z350boy
I beg ti differ. There is a filiter located behind the battery compartment.
Old Jun 2, 2008 | 08:48 AM
gothchick's Avatar
gothchick
^^^ Actually, there's no filter there. Just the vent intake... You can see right down into the fan blades.
Old Jun 2, 2008 | 08:49 AM
JSDZ33's Avatar
JSDZ33
i thought all cars have cabin filters. they are mandatory now rite?
Old Jun 2, 2008 | 08:54 AM
SpoilsofWar's Avatar
SpoilsofWar
Removing the entire AC system solved the problem for me...
Old Jun 2, 2008 | 09:05 AM
DavesZ#3's Avatar
DavesZ#3
Beg all you want - it doesn't change the fact that the Z does not have a cabin air filter.
Old Jun 2, 2008 | 09:13 AM
Fairly Z's Avatar
Fairly Z
Spray perfume in the vents.
Old Jun 2, 2008 | 09:54 AM
Z04's Avatar
Z04
if you try and say "the dealer said it is there" we will still tell you they are wrong. if you got your car serviced and they charged you for replacing it, you got ripped a few dollars since there is nothing to replace
Old Jun 2, 2008 | 09:56 AM
Z04's Avatar
Z04
um, only if you are a girl. plus that might not be a good idea because that stuff (as with cologne) is very thick and when it dries, it builds up and over time will begin to stink.
