No power to HID
Old Jun 20, 2008 | 03:16 PM
wesismyhero's Avatar
wesismyhero
Default No power to HID
My passenger side HID went out. I replaced the bulb and nothing. So I put a meter on it and it isn't getting power. I checked all the fuses and they are good. Any ideas what to do next?
Old Jun 20, 2008 | 07:44 PM
gregom's Avatar
gregom
Sounds like a dead ballast maybe... they do die sometimes but its pretty rare, especially an OEM one that came with the car.
But you could try taking your headlamps out (I think you have to take the bumper off), then remove the ballasts and swap them... See if your left works on the right side. Or you can just unplug the ballast on the right side and see if power is getting to the wiring before the ballast.
Old Jun 20, 2008 | 09:02 PM
Pin69's Avatar
Pin69
Or you can talk to Nic at Cincitydesigns (if you continue to have problems.)
Old Jun 23, 2008 | 02:16 PM
wesismyhero
Thanks guys. Any idea how much a new ballast would run me?
Old Jun 23, 2008 | 03:07 PM
gregom's Avatar
gregom
I don't know if you can get just a new OEM ballast... maybe check wrecking yards? You might have to buy an entire headlamp assymbly because the ballast comes attached to it. But I dunno, you can call a Nissan dealer and ask. Or you can probably buy some other OEM ballasts for other cars at www.hidplanet.com or some other HID specialty shop.
Old Jun 23, 2008 | 04:06 PM
Nic@CiNcity's Avatar
Nic@CiNcity
OEM ballasts are very common and are ALL OVER ebay. If you've checked everything else, I'd go with that. Did you verify that your ballast is even connected? I've had lights shipped in to me where the connector had broken loose. You might want to do a double check and use the ballast from the other light to see if it does indeed cure your problem.
Old Jul 2, 2008 | 10:14 PM
wesismyhero
So somedays I have a headlight and somedays I don't. I can start the car and it will be on, drive twenty minutes and it goes off. wtf?
wesismyhero
Pleask
Dec 21, 2021 03:17 PM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
