help removing the 350z badge
Old Jul 3, 2008 | 06:43 PM
frankie's Avatar
frankie
Default help removing the 350z badge
how do you remove the 350z badge i am intersted in geting the fairlady z. i do know that you need dental floss but what else do i need and how would i get it straight.
Old Jul 3, 2008 | 06:50 PM
SlowZster's Avatar
SlowZster
some goof off, or equilevant. That's all I used...
Old Jul 3, 2008 | 06:58 PM
frankie's Avatar
frankie
ok thanks but what do i do about geting it stright
Old Jul 3, 2008 | 07:00 PM
imjdoggie's Avatar
imjdoggie
heat gun and fishing line or floss
Old Jul 3, 2008 | 07:02 PM
imjdoggie's Avatar
imjdoggie
get it straight by lining it up where the 350Z was, you should be able to get a general idea where it was..........
Old Jul 3, 2008 | 07:16 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
You might use a compass (like for drawing circles). Put tape on the sharp point and use a grease pencil instead of a regular pencil. You could then key off of the edge of the trunk lid to draw a reference line.
Old Jul 3, 2008 | 08:01 PM
ncparamedic's Avatar
ncparamedic
Prodigal Son
i think im having deja vous
Old Jul 3, 2008 | 09:44 PM
SS728's Avatar
SS728
You can really just use your fingers to pry it off, use some goof-off to help remove the adhesive.
Once removed, clean up the adhesive nicely, maybe some handwax to add some protection.
If you are buying a "FairladyZ" emblem, it comes with a template, and all you do is line it up with the end and left side of your trunk and peel off the adhesive backing.
Old Jul 4, 2008 | 01:24 AM
terrasmak's Avatar
Please don't unless you have a RHD Fairlady Z
Old Jul 4, 2008 | 07:50 AM
300zx1985's Avatar
300zx1985
... why?
Old Jul 4, 2008 | 07:58 AM
michaeljr6's Avatar
michaeljr6
Old Jul 4, 2008 | 10:48 AM
jinsei888's Avatar
jinsei888
Use a blow dryer to heat up the entire emblem area with a left-to-right motion, and as your doing that, progressively use the floss to "floss" off the badge, separating the glue from the painted-body of the trunk.
Take your time, there's not need to rush!
When all is off and the remaining glue is still on the painted-body, use a Goo-gone type liquid remover and rub off the remaining adhesive with a soft cotton cloth--also take your time doing this, don't rub your surrounding paint surface to high heaven!
When you get the Fairlady Z badge (hopefully that's what your getting) it comes with a blue styrofoam-like template so that you can line it up against the trunk's lower edge so that the emblem sits in its correct OEM position!
Tah-dah! Done! Goodluck!
Old Jul 29, 2008 | 01:21 PM
mariar508's Avatar
mariar508
after you take the stock 350z badge off, will you still be able to see where it was even after you clean the area and everything?
Old Jul 29, 2008 | 01:24 PM
ny garbage_juice's Avatar
ny garbage_juice
waiting for answer, id like to remove mine but not if its f*cked up under there
Old Jul 29, 2008 | 01:28 PM
300zx1985's Avatar
300zx1985
You wont know untill its off.... some cars are garaged 24/7, others are outside 24/7. Mine is outside all day everyday, so when I removed mine you can faintly see the "350z" in certian light. If its ****ed just put another 350z badge back on
Old Jul 29, 2008 | 02:03 PM
KornerCarver's Avatar
KornerCarver
I took of my 350Z emblem and didn't replace it with any emblem. I think it looks much cleaner without any emblem. Now if I could just get rid of the large Nissan emblem.
Les
Old Jul 29, 2008 | 10:19 PM
joe645733's Avatar
joe645733
Originally Posted by 300zx1985
... why?
cuz the fairlady emblem is played out if you dont actually have an actual fairladyz. (RHD) and maybe some other things?
Old Jul 29, 2008 | 10:20 PM
joe645733's Avatar
joe645733
just use a credit card. then buff the rest out.
i used an adhesive remover to get the sticky stuff out. but in the sunlight, you couldve still seen 350z imprinted on the trunk. so i buffed it.
Old Jul 31, 2008 | 06:52 AM
MarvinMartian's Avatar
MarvinMartian
Les
+1000
I did this last night.
Used some regular dental floss (I think waxed floss might have been better).
Left quite a bit of residue on the hatch.
A little "Goo Gone" and a clean, soft white towel helped remove all the remaining residue.
Love the look.
Old Jul 31, 2008 | 07:02 AM
ny garbage_juice
i wish the Nissan emblem came off as easy. It needs to come off to get the real clean look i want
i dont know if just removing the 350z one does it for me
