Do it yourself Blue Tinted Bulbs
I didn't like how the driving lights looked in front - the were too orange / halogen looking. None of my local part stores carried 194 bulbs that were blue tinted, so I thought I'd try and make some myself.
First the before pic:
Then I started coloring the bulb. This is where you have some fun. After it is all colored in (do it fast) start wiping it off with a lint free towel. Depending on how wet the ink is, how thick you applyed the ink, and how much rubbing you do, you can get various levels of tint.
And here is the result. Now I know what you are thinking, base model owners - I'll do that to my headlights. Nope - it won't work. The extreme heat will vaporize the ink right off the bulb. This process only works for low voltage bulbs like the driving lights and the interior lights. But its cheap and a fun do-it-yourself project.
Originally posted by SharpST77
ghetto?
ghetto?
I am not a fan of any coated bulb really, but I wouldnt knock someone who decides to take a 3 dollar marker to a set of parking lamps. Looks like he's ending up with the same results and at a fraction of the $10/pair pricetag that they sell those over-priced blue bulbs at. Again, its no wonder APC is rolling in the money.. they serve cow-dung on a plate and people readily buy it.
A little correction though, all of the halogen bulbs on the Z are the same voltage (12 volts), its the amount of current they consume which is different (watts). Those small lamps are parking lamps, they use no more than 5 watts usually.. and generate very little heat. You may be able to get away with coating the turn signal bulbs, but NOT the headlamp bulb. Headlamp bulbs create an excess of 300° F and can easily explode -- they should not be tampered with.
- Mike / ClearCorners.Com
They would look ghetto if my car wasn't blue. Unless you got your head right down in there, you wouldn't even see them. I just tinted them a little bit - to whiten the light a bit. I was changing the headlights anyways - so I was there . . .
the color will burn off. i tried this before using both a permanent marker and a overhead projector pen. the color will fade and eventually burn off. its a good idea i thought at the time, but after going back to the bulbs to redo them, it was just too much of a hassle.
