Gas tank removal pictures?
Old Oct 10, 2008 | 09:42 AM
unit5alive's Avatar
unit5alive
Smile Gas tank removal pictures?
Hi guys I'm been searching for a old thread someone posted , it showed gas tank removal pictures ,to replace the vapor hoses that crack, anyone have a link ? thanks in advance , Craig.
Old Oct 12, 2008 | 04:52 AM
yogipower's Avatar
yogipower
try local nissan dealership from near you.
Old Oct 12, 2008 | 06:10 AM
unit5alive's Avatar
unit5alive
Angry
Every singe time that the car has been to the dealership it has been screwed up so badly that our lawyer has had to straighten it out , people just don't care anymore , if the motor had blowen up in this car it would probably end up parked for years for someone else to repair and enjoy , rather than take it to the dealership to screw up further, thats why the car has never had the fuel hose recall done ,the last time it was driven in the spring just before the warranty ran out , (I wanted to drive it a little more than the 100 miles its been driven each year for the last 3 years), then the car filled with fumes , so one of the hoses must of cracked, its a shame because the car just turned 5k , if I could get 20k for the car after the hoses are replaced I would sell it , but thats not going to happen, Craig.
Old Oct 12, 2008 | 06:22 AM
Dr. Venture's Avatar
Dr. Venture
make the trip to jerzee, and i'll do the job for you!
Old Oct 13, 2008 | 04:10 AM
unit5alive's Avatar
unit5alive
Smile
Dr Venture, thanks for the offer , I can do the job, but I guess what I'm getting at is, what happen to pride? (I think the problem is called flat rate) most mechanics I know use a impact for everything, I use a torque wrench for anything that lists a spec, Craig.
Old Oct 13, 2008 | 05:48 AM
Dr. Venture
haha time is money my friend. you can use a small impact gun to take things off that are torqued to a precise lbs. When re installing the nuts and bolts is where a tq wrench comes in handy. cause by the time you wris action every bolt off i dont think your going to want to wrist action them back on as well!
Old Oct 13, 2008 | 06:31 AM
unit5alive's Avatar
unit5alive
Smile
I use the impact wrench for mainly removal , Craig.
Old Oct 13, 2008 | 07:57 AM
Dr. Venture
less you smell gas, and or the hose is leaking....dont bother with taken the tank down.
Old Oct 13, 2008 | 08:22 AM
VO...'s Avatar
VO...
Administrator
It's in the maintenance section somewhere as I recall. I plan on doing this myself also when the time comes...
Old Oct 13, 2008 | 09:31 AM
unit5alive's Avatar
unit5alive
Arrow
I smell gas , but no leaks.
Old Oct 13, 2008 | 09:35 AM
unit5alive's Avatar
unit5alive
Arrow
Their was a post on here a few years back , a guy took pictures of the whole job , but I can't find it !
Old Oct 13, 2008 | 09:59 AM
Dr. Venture
if you can give me a fax # i can fax you the complete destruction's!
Old Oct 13, 2008 | 10:15 AM
unit5alive's Avatar
unit5alive
Arrow
Dr Venture , I PM'd you the work fax number , Thanks Craig.
Old Oct 13, 2008 | 11:50 AM
unit5alive's Avatar
unit5alive
Thumbs up
Dr Venture , got the fax , thank you very much , this should make things go much smoother , I do have the stack of white Nissan dealer service books for reference , it doesn't look to bad , I wish I had a lift though , Craig
Depravity
Oct 1, 2015 04:49 PM
