Asuka doublehump roof problem....HELP!!!!
Old Oct 10, 2008 | 03:25 PM
timmays350's Avatar
timmays350
Default Asuka doublehump roof problem....HELP!!!!
Got the roof installed just fine fits great. but for some reason it goes under the a pillar molding. once installed the pop clips on the molding no longer reach. I tried 3m tape, but now there is a gap under the bottom side. any suggestions or input would be appreciated. thanks
Old Oct 10, 2008 | 03:27 PM
Chebosto's Avatar
Chebosto
pictures? its probably hitting the edge of the a pillar piece.. maybe u need to sand it down?
Old Oct 10, 2008 | 03:33 PM
timmays350's Avatar
timmays350
I'll get some pictures up tomorrow, gettin dark here probably won't turn out to good.
Old Oct 11, 2008 | 08:51 AM
timmays350's Avatar
timmays350
1/4 inch gap that wasn't there before.
yes I broke it!!!
end product. not to bad I kinda like it.
Old Oct 11, 2008 | 09:16 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Timmay-
Where is that 1/4" gap? I forwarded your questions and pictures you PM'd me to brad over at Asuka. I'll PM you his reply with pointers he might have. You're one of 2 people who have actually installed this roof, so I doubt there will be much help here.
Jim
Old Oct 11, 2008 | 10:29 AM
Changvi's Avatar
Changvi
I have the Mastergrade roof car instead of Asuka. You were not suppose to tuck the edge underneath the molding because it will create stress. Instead, over the molding. Thats what I did with mine, and it looks great. Hope this helps.....
Old Oct 11, 2008 | 01:10 PM
timmays350's Avatar
timmays350
yeah it has to go under the molding there is quite a bit of material that follows the contour of the unibody. that 1/4 inch gap is on the lower side of the molding. instead of sitting flush, there is nothing backing the molding up it's pretty much just held there by double sided tape.
Old Oct 13, 2008 | 04:40 PM
eXe-Chris's Avatar
eXe-Chris
Timmay, I told Jim I would clue in on this one. What we did is took the pillars off and pop riveted it into the roof. Then we sanded down the edges and molded it into the exsisting roof. It sounds liek a bunch of work but it really wasn't that bad at all. If you are beyound the point of pop riveting you could always mold it in and you will have no problems. Let me know if I can be of anymore help.
Here are a few pics of mine:
Old Oct 13, 2008 | 10:54 PM
blackz123's Avatar
blackz123
dude it looks fine
Old Oct 14, 2008 | 05:34 AM
Jim@Showstoppers
Brad from Asuka is gettng me some pictures and instructions today.
Jim
Old Oct 15, 2008 | 05:04 PM
Jim@Showstoppers
Here's what I was given by Asuka, I hope this helps:
"look at the pics with the screws tap into the edge of the roof cap front to back along the edge of the roof cap, these pieces you will have to drill a small hole and screw the roof down, be careful not to over tighten those pieces (flat screw head should be better for clearance), the 3M tape should go from one side of the car to the other side (driver to passenger) front and back, if you notice as well the front winshield molding goes over the top of the roof cap.....this should give you enough clearance for the pillars as well as securing your roof from extreme speed, you could have a third screw midway each side if you're still insecure about having the roof flying off. hope this helps."
Old Oct 18, 2008 | 10:47 PM
timmays350's Avatar
timmays350
hey thanks for all the good input guys, Chris, Jim I really appreciate it. I'm gonna have to wait to try any of this though being I'm back in iraq so I'll let you guys know in January how it all went down. again I really appreciate the help.
SharX59
Sep 27, 2015 09:23 AM
KJ-350
Mar 6, 2006 02:59 AM
vice86
Jun 3, 2003 06:25 PM
