Cabin/Dash Squeeks
Old Oct 14, 2008 | 07:17 AM
350zWVU's Avatar
350zWVU
Default Cabin/Dash Squeeks
So, I have recently noticed these squeaking noises in the cabin under/in the dash. Tried to do a search on the forum with no success. It seems like the creeks and squeaks go away after the car warms up. (sounds like plastic rubbing together).
Also, the squeaks only happen when the car is moving over the road. Its almost like the dash is designed to not have any give and something is giving. The post below is good, but doesn't get to the answer. But, thanks anyway.
Any assistance on this problem would be very welcomed. I don't yet want to take it to the dealer until I know more.
2006 Touring
8,500 miles
AT
Old Oct 14, 2008 | 07:49 AM
WTX350Z's Avatar
WTX350Z
This is the trouble with plastic interior panels that snap together...they squeak, rattle, buzz, moan, and groan.
To minimize this you can apply a foam tape to the edges of all the panels and around attachment points. It will help...but then it makes every "new **** and moan" blatantly obvious...which is at least slightly irritating. (I hate rattles, buzzes, etc...and have taken 1/2 my interior apart to minimize....its only a matter of time before I remove everything.
I know toyota has a part that consists of different adhesive foams...but I'm not sure if Nissan does this as well. I would rather do it myself than trust the morons here...as taking the panels off can create new noises.
Originally Posted by 350zWVU
So, I have recently noticed these squeeking noises in the cabin under/in the dash. Tried to do a search on the forum with no success. It seems like the creeks and squeeks go away after the car warms up. (sounds like plastic rubbing together)
2006 Touring
8,500 miles
AT
Old Oct 14, 2008 | 09:00 AM
Charles Field's Avatar
Charles Field
check out this thread
https://my350z.com/forum/exterior-in...me-insane.html
Old Oct 15, 2008 | 05:48 AM
a. Take the dash apart.
b. Wrap stuff with thin foam padding.
c. Put the dash back together.
You will end up with twice as many squeaks as then you started. Really.
jtekk
Oct 10, 2005 05:25 PM
marco_mendoza
May 11, 2005 01:33 PM
myz8a4re
Oct 26, 2004 01:28 PM
orhanz33
Oct 20, 2004 02:48 PM
Static
Apr 26, 2004 11:37 AM
