squeeking, not brakes
Old Apr 16, 2005 | 07:33 AM
marco_mendoza's Avatar
marco_mendoza
Default squeeking, not brakes
hey guys, hearing a squeeking noise as i drive on the streets coming from the front driver's side wheelwell. it's not the brakes, cuz i just changed them two months ago. one day, when i closed the door,(parked) it also squeeked from the wheelwell, could the squeek be my struts?
Old Apr 18, 2005 | 11:02 PM
time4aspliff's Avatar
time4aspliff
I've also got an intermittent squeaking noise. It seems to be coming from either my wheels/axles, brakes or chassis. It's sometimes loud enough to hear over my radio.
It's a very dissonant metal on metal noise. I sometimes hear it quite distinctly when I'm driving at low speeds in parking lots. It's turning heads for all the wrong reasons...
Does this ring a bell for anyone else? It's driving me crazy...
Old Apr 20, 2005 | 08:29 PM
marco_mendoza
Red face
i know, that squeek sucks. sounds like a bird chirping, and that's exactly what i thought it was until i reminded myself that i'm in los angeles.
anyone know what it could be??? i'm off the warranty
Old Apr 20, 2005 | 08:51 PM
NTRIGUE's Avatar
NTRIGUE
I had it from 3000-5000 very intermittently then 12k-14k. Goes away if you yank the e-brake?!
Old May 2, 2005 | 03:31 PM
time4aspliff
Perhaps the noise is the e-brake rubbing on something?
Old May 2, 2005 | 05:26 PM
andyisphat2004's Avatar
andyisphat2004
just a shot but they buy a grease that you can put on the back of your pads to stop squeeking, that is if it is the pads. I just put hawks on, which people have said squeek and i dont hear a sound.
Old May 3, 2005 | 01:47 PM
time4aspliff
This particular 'squeak' is present when I'm not applying my brakes. (i.e. when I'm either driving or coasting at low speeds)
I sometimes hear squeaking from my Brembos (when I apply them) but I'm not sure if these squeaks are in any way related.
I'm starting to think that one noise is coming from my Brembos and the other "chirping squeak" might be coming from my e-brake pad which might be rubbing against something.
Old May 3, 2005 | 01:56 PM
NTRIGUE's Avatar
NTRIGUE
Almost suspension related and definately different than brake squeak.
Old May 9, 2005 | 04:59 PM
carbon_15's Avatar
carbon_15
mine never did it before, but the other night i kind of ran over a concrete median while running from "the man". doesnt drive any differently, but ive got a squeak somewhere from my left front wheel that i can hear thru first and second.
Old May 9, 2005 | 06:08 PM
Conceyted's Avatar
Conceyted
I have the bird noise, only heard when the window is DOWN and when i hit small bumps. Its from the driver side and sounds like mine is the door panel. Well today I made an interesting discovery, the sideview mirror is causing my squeak, so I will be taking it apart and trying to fix it sometime this week.
Also I have a clunking type noise in the front suspension area. Sounds metal on metal but not a squeak. I will be taking apart the entire front suspension and retightening everything with an impact gun very very soon. That clunk will be dead if its the last thing I do.
Old May 10, 2005 | 05:37 AM
Sly_Z's Avatar
Sly_Z
I'm also getting the squeaking noise, I just changed all my pads because I thought it was coming from the brakes. have anyone found out exactly where its coming from?
Old May 10, 2005 | 07:14 AM
Sly_Z's Avatar
Sly_Z
Andy, what's the name of that grease.
Old May 10, 2005 | 09:43 AM
Conceyted's Avatar
Conceyted
just use anti-sieze... works the same
Old May 10, 2005 | 04:09 PM
Z-U-L8R-H8R's Avatar
Z-U-L8R-H8R
i am also having that same noise but from the right rear tire it does it all the time but when i hit the brakes it does it a little bit louder please some1 post if they know it because i am about to get rid of the car if it continues because there is no reason a 30,000 dollar sports car should do that it is embarresing.
Old May 10, 2005 | 04:40 PM
Conceyted's Avatar
Conceyted
Umm, we also own a 45,000 (bmw z4) sports car and theres tons of rattles. Granted it IS a convertible, but rattles happen in all cars, escpecially when you start modding it.
Old May 11, 2005 | 01:33 PM
Sly_Z's Avatar
Sly_Z
thanks
07ZEKE
Aug 23, 2021 09:15 PM
samansharif
Sep 25, 2015 12:31 PM
