Headlight opinions needed..
Old Nov 1, 2008 | 10:33 AM
TheOtherRob's Avatar
TheOtherRob
Oh I see. Well I hope it works out for you! Those headlights look very good. I just dont have the ***** to open mine up right now. Ill probably get it done one weekend...
Old Nov 1, 2008 | 02:53 PM
sam2944's Avatar
sam2944
10k have less lumens (light intensity) due to have more blue than white. This is a simple explanation, more if you study the Kelvin Scale of light....... Replacing your oem HIDs or adding a conversion kit is a big upgrade, in lighting and also the car looks very nice. Hope this help. www.sagahid.com
Old Nov 1, 2008 | 04:34 PM
A.H's Avatar
A.H
Go for it. They look so much better in real life than in pics. Just maek sure you dont' mess up lol. BTW in teh pic you can see the right headlight has more "dust" inside than the left one. Anyway to get this dust out of the headlight without taking it apart? And I still dont' know why these turn signasl still don't work
Old Nov 1, 2008 | 05:30 PM
OldDirty Z33's Avatar
OldDirty Z33
wow that sucks good luck
Old Nov 1, 2008 | 06:00 PM
redlude97's Avatar
redlude97
Who the heck told you that? Range rovers do not come with 6k bulbs, they get their color from their cutoff, just like every other OEM manufacturer.
Originally Posted by A.H
At first I loved the OEM bulbs but I also really like the bulbs they had in range rovers whcih i found out were 6k. So i gave those a shot and really liked them, although I did loose visablility. And ever since I've just got use to 6K visability which is why I never push my car unless it's light out. The 10,000K bulbs are my friends and he gave them to me for free so I thought about giving them a shot but they defiently won't work. If 6K visablitly wasn't bad enough 10K jsut makes it worse I really wanted to stop spending money a while ago and I would just put in my OEM bulbs at this point to be honest but I only have one
Old Nov 1, 2008 | 06:10 PM
A.H's Avatar
A.H
I heard that from a couple peopel but didn't bother looking it up. It didn't seem too crazy since their lights along with the new escalade's lights have more blue in them then other cars with xenons.
Old Nov 1, 2008 | 07:55 PM
sam2944's Avatar
sam2944
Oem cars HID temps are about 4,300 (like Z) and 5,800 (BMW). Projector type beams make the light look different depending the angle you see the light. 5000k and 6000k is where you will found better lighting benefits. But finally decisions are particular. www.sagahid.com
Old Nov 2, 2008 | 05:46 AM
TheOtherRob
I think if I felt the need to ever change the bulbs I would go with somewhere around 5k max. The STI lens from afar is going to make your stock HIDs look very blue due to the very sharp cutoff.
A.H, about getting the dust out. The only thing I would try is to take the headlight off the car and try blow some air into it with a compressor on a lower setting to see if you can blow some out. Or maybe even try one of the household dusters that retain dust once you pass over it. Im surprised Cincity would have any in there considering they do it every day.
Old Nov 3, 2008 | 11:42 AM
redlude97's Avatar
redlude97
This is false. All current model BMW's use 4100k bulbs, the only bulbs that BMW ever used that were not 4100k, were the Philips 85123 which was never officially released from philips, and is closer to 5000k. These were only used in early HID equipped BMWs with e46 style projectors, and only for the first few model years.
Old Nov 3, 2008 | 08:31 PM
A.H's Avatar
A.H
Ok you guys I need help and fast. After searching on the forum everyone seemed to recommend that 7440 bulbs fit perfectly in teh front turn signal and that the best brand were the luxeon. Well i got them and they cost 50 bucks and they don't fit my car. They did however fit my freinds G 35 perfectly......I need to know asap what the right bulb number is so I can order it and have my car running again. I haven't driven my car in like 5 weeks because of headlights and I miss it dearly. Any suggestions are extremly appreciated. Thx
-Arsh
Old Nov 4, 2008 | 06:14 AM
TheOtherRob
I usually go here for reference.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Old Nov 4, 2008 | 06:16 AM
TheOtherRob
Looks like you got the wrong bulbs. If those 7440's are white, then use them as back up lights.
Old Nov 4, 2008 | 07:52 AM
A.H's Avatar
A.H
then what do I get for the front turn signal? I can't find the 3457. And which are the back up bulbs. You mean rear turn signal?
Old Nov 4, 2008 | 09:31 AM
o2sys's Avatar
o2sys
When you say STI lens do you mean the actual projector lens from the impreza STI?
Why would you do that? the lens on the STI is horrible! I wanted to swap my lens for some TSX ones...
Old Nov 4, 2008 | 09:36 AM
TheOtherRob
Its a replica of the JDM Sti lens. The lens is perfectly clear with allows a much sharper cutoff compared to the factory beveled lens.
A.H. The site that I linked says that the 7440 is the back up light (Reverse Light).
Old Nov 4, 2008 | 09:38 AM
TheOtherRob
Here are the bulbs for 3457. Ive bought ALOT of led's through this site and they have all worked great and never failed.
http://autolumination.com/3157_3156.htm
Old Nov 4, 2008 | 03:48 PM
sam2944's Avatar
sam2944
Hey Red, as distributor I contacted direct BMW technical department and this was his response. For your knowledge, every headlamp project color K in a different way so a firm K can not be obtained from any auto manufacturer. Philips DO NOT make any HID (this is market tricks), they only supply the HID "burner" to manufacturers, so the xenon, noble gases and salts mixture inside the bulb is a matter of the production line. Also know that projection type beam has a plate inside that makes the color of the bulb looks different depending on where you look to the lamp. I DONT NEED TO STATE ANY FALSE INFO. So please be more smart when post your personal opinion. I have 2 years experience in at large distribution of this kind of sytems and sell locally, international, eBay, etc.
Old Nov 5, 2008 | 06:36 AM
  #38
sam2944's Avatar
sam2944
AH go to VLEDS.COM for the turn signal leds. They have a high-power led that can be easy visible in daytime. Remember to add load resisitors. www.sagahid.com
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
wanderingstuden
Jan 28, 2016 07:03 PM
JGee450
Sep 30, 2015 04:32 AM
samansharif
Sep 25, 2015 12:31 PM
