No "pop trunk" button in Z?
Old Nov 6, 2008 | 08:47 AM
avandss's Avatar
avandss
i see his point, usually cars have a hatch release button inside the cabin
maybe you can find a button from the another nissan and place it in an empty slot
Old Nov 7, 2008 | 05:57 AM
o2sys's Avatar
o2sys
thats what i was thinking...just wire it from the trunk all the way to the dash or find somewhere within the dash to do so...l
I dont mind it being on the outside...but for my passenger i have to get out to do it for them and that gets annoying
Old Nov 7, 2008 | 07:47 AM
Ichigo's Avatar
Ichigo
<o:smarttagtype namespaceuri="urn:schemas-microsoft-com<img src=" forum="" images="" smilies="" redface.gif="" border="0" alt="" title="Embarrassment" smilieid="3" class="inlineimg"></o:smarttagtype><o:smarttagtype namespaceuri="urn:schemas-microsoft-com<img src=" forum="" images="" smilies="" redface.gif="" border="0" alt="" title="Embarrassment" smilieid="3" class="inlineimg"></o:smarttagtype><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1026"/> </xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]-->
j/k just jumping on board
Old Nov 7, 2008 | 07:52 AM
Bret86944's Avatar
Bret86944
What do you mean? Why don't you just tell them where the button is?
Old Nov 9, 2008 | 10:05 AM
aloh's Avatar
aloh
im pretty sure he meant if there was one inside the car.
There isnt one inside the car unless you count that retarted emergency on under the rear bar. None of my new passengers can ever find the button above the license plate cause its so flush.
One of my few gripes about the Z...
Old Nov 9, 2008 | 10:16 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
RTFM = read the fuking manual.
Old Nov 9, 2008 | 10:18 AM
JCat's Avatar
JCat
It is a security feature. If someone breaks into your Z they can't get into the trunk.
Old Nov 9, 2008 | 11:12 AM
dfresh713's Avatar
dfresh713
Master
Where is the button under which rear bar? A bodyshop lost my clicker and I havent been able to get back into my trunk since.
Old Nov 9, 2008 | 11:15 AM
Nismospeed4life's Avatar
Nismospeed4life
A typical case of not reading your owners manual.
Old Nov 9, 2008 | 01:03 PM
mariar508's Avatar
mariar508
this is a ridiculous amount of posts for a very simple answer
Old Nov 9, 2008 | 01:26 PM
sam2944's Avatar
sam2944
The button is inside the front dash glove compartment....... je, je......
07ZEKE
Aug 23, 2021 09:15 PM
Workshop12
Mar 23, 2020 01:45 PM
kyin
Oct 15, 2015 05:54 AM
B Esquire
Sep 24, 2015 07:52 AM
