07+ reflector question
Old Nov 25, 2008 | 04:28 AM
ZMAN1AC's Avatar
ZMAN1AC
Default 07+ reflector question
Is it possible to switch out the stock front reflectors without taking off the bumper?
Old Nov 25, 2008 | 04:36 AM
07rdsterGT's Avatar
07rdsterGT
Yes, search for threads started by me, you'll find a write up.
Old Nov 25, 2008 | 04:39 AM
07rdsterGT's Avatar
07rdsterGT
https://my350z.com/forum/exterior-in...-write-up.html
here you go, you'll notice theres a real ***** in my thread. You'll probably see him in here later telling you to use the search function, lol.
Old Nov 25, 2008 | 08:55 AM
robbinsj's Avatar
robbinsj
Possible but kinda a pain, I can remove the bumper to quik to avoid it.
Old Nov 25, 2008 | 09:51 AM
ZMAN1AC's Avatar
ZMAN1AC
ahh, thanks were they easy to reach once u remove the plastic guard?
nvm, found the answer to my question in the thread u gave me thnks a lot!
Old Nov 25, 2008 | 04:48 PM
trodis's Avatar
trodis
i tried doing it w/o removing the bumper and could not get through the windshield washer res. Had to remove the bumper. I'd like to know the method and tools u used in doing so.
Old Nov 26, 2008 | 03:49 AM
07rdsterGT's Avatar
07rdsterGT
My hands and brain. I'm not trying to be a smart *** but the res was barely in the way. Get your hands in there and do work son! Tools are listed in my write up.
CLIFF NOTES
Lift car, drop skid plate, pull the side plastic splash gaurds back to get your hand in there with a screw driver, remove then install. Put the skid plate back on and drop car. (You will be on your back and semi-under the car for this so use safety jacks!)
Old Nov 26, 2008 | 11:21 AM
Justins08350z's Avatar
Justins08350z
i accomplished it on my 07. i just took out the inside wheel wells and used a small phillips screwdriver but the passenger side was a pain because of the washer fluid but after awhile i was able to get behind it without having to take anything off. i did use his thread though and it helped me
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
