Noise from passenger door
Old Dec 4, 2008 | 05:30 AM
Sixth_Vang's Avatar
Sixth_Vang
Default Noise from passenger door
Hello,
I'm getting a lot of wind noise from my passenger side door when i'm going at higher speeds. When it rains it's fine, no water gets through. Took it to a high pressure automatic washer and water got through. It came from the top left *assuming that you're sitting from the drivers side facing it*.
Any suggestions on how to fix it?
Thanks,
JV
Old Dec 4, 2008 | 05:48 AM
350Zenophile's Avatar
350Zenophile
There is a reset procedure for getting the window to seat properly after you close the door. I don't know it off hand but search here and you'll find it.
Old Dec 4, 2008 | 07:46 AM
Sixth_Vang's Avatar
Sixth_Vang
Thanks zenophile, i'll look into it. I do know that the window motor has been replaced so maybe they didn't do it right. The window goes up but probably not the way it should? *shrugs*.
Will report back with an update.
Old Dec 4, 2008 | 08:20 AM
3-fifty-WeEe's Avatar
3-fifty-WeEe
k dummy.. all you do is take off your outer skin, THEN u see the sheet of steel.. well in that sheet there are black circles some sort of seal.. well the window motor is mounted on the insdide of the steel sheet.. locate where the motor sits .. THEN once motor is found there will be a black seal.. well under the seal is your window motor reset button. wind ur window to the bottom( need to plug in the part for ur arm rest) then hit the button, hold for 10 sec. motor reset.
Old Dec 4, 2008 | 10:12 AM
350Zenophile
or...since you neglected to mention the motor replacement...take it back to the place that replaced it and have them do it.
Old Dec 4, 2008 | 01:47 PM
Sixth_Vang's Avatar
Sixth_Vang
I'm not sure who did it, the first owner had it done. I'm the third owner.
And to three fifty......thanks I will try it.
Obadabot
Jun 18, 2023 11:31 PM
Rev_Night
Nov 7, 2020 06:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
samansharif
Sep 25, 2015 12:31 PM
