Is a short hub needed
Old Jan 5, 2009 | 06:53 PM
chopperman's Avatar
chopperman
Default Is a short hub needed
Purchased an aftermarket wheel and NRG v2 quick release. Also I purchased a momo stardard size hub. Do I need to get a short hub or will the stardard momo hub do the job. Is it going to stick out too much with that hub. If not then im going to pick up a NRG short hub to stay with the theme. Also if I pick up the NRG short hub I want to make sure that it is plug and play with no modifications needed. Does anyone have one, and how do you like it? Pics
Old Jan 5, 2009 | 09:58 PM
Chebosto's Avatar
Chebosto
typically standard length hubs will make the steering wheel at normal length (distance) as oem wheel.
shorty hubs are used with Q/R and/or tilt steering wheel mounts.
Old Jan 6, 2009 | 12:10 AM
Chad68's Avatar
Chad68
Most people have problems with the Momo hub adapters.
Bell works hub is the way to go. Here is a pic of my Momo wheel, Bell Works short hub and NRG V2 QR.
My wheel is about 1" closer than stock.
How close your wheel will be depends on, your wheel dish, as well as what hub (short or long) and your QR (reg. or thin) if you use one.
Attached Thumbnails Is a short hub needed-12.jpg   Is a short hub needed-11.jpg
Old Jan 6, 2009 | 01:33 AM
datsunHEAD's Avatar
datsunHEAD
momo hubs suck,I had one on my 240sx and some how the inside of the hub where the stick thingy goes for the steering wheel grinded the little teeth off,so here I am on the highway going into a turn when I slightly start turning my steering wheel but the cars not turning, so I really turn the steering wheel to the left and it just spins freely,so im on the freeway with no steering imput and i panic and slam on the brakes and the car slid of the shoulder,since then i vowed never to get another a/m steering wheel again
Old Feb 12, 2009 | 02:28 PM
SpeedNStylez_JL's Avatar
SpeedNStylez_JL
I found this online regarding a NRG short hub compared to a WORKS BELL short hub.
NRG_Innovations_Super_Street_May_20.jpg?t=1234480755
Old Feb 12, 2009 | 02:33 PM
SpeedNStylez_JL
I talked to the guys at NRG and they have a short hub coming out sometime this month. they e-mailed me pics of a install they did on MRxDELUXES car on this forum...
IMG_3670.jpg?t=1234481417
IMG_3634.jpg?t=1234481504
MRxDELUXE went to NRG when his WORKS BELL HUB cracked...
IMG_3648.jpg?t=1234481535
IMG_3647.jpg?t=1234481586
Old Feb 12, 2009 | 04:04 PM
johzp's Avatar
johzp
^^what time this month? Will it come with resistors for airbag delete?
Old Feb 12, 2009 | 04:40 PM
SpeedNStylez_JL
They said end of this month and yes it comes with resistors...
Old Feb 12, 2009 | 04:58 PM
ekidd's Avatar
ekidd
I had the nrg slim hub on my EK and it looked awesome. Right now i have the momo hub on my Z with no problems what so ever. Im running the momo hub, FET style QR, and a nardi 330 deep corn.
Old Feb 12, 2009 | 04:59 PM
eXe-Chris's Avatar
eXe-Chris
HEY OP!
I have the exact same setup (NRG quick release gen 2.5, NRG steering Wheel, Momo Hub). Your momo hub will work and look great. Go throw it on your gonna love it!
Old Feb 12, 2009 | 05:08 PM
NightRider88's Avatar
NightRider88
I have the Works Standard bell hub and the 2.5 nrg quick release...I love it....but now im scared so i spirite drive everyday.....what is the likley hood that the hub will crack???
Old Feb 12, 2009 | 10:21 PM
SpeedNStylez_JL
The works bell hub that i've seen has very thin metal walls as well as the middle hub spline looks like cheap metal. I've seen the NRG hubs and they are very nice quality hubs very thick especially where the teeth are
Old Apr 23, 2009 | 09:19 AM
SpeedNStylez_JL
NRG hubs are in
Old Aug 8, 2009 | 08:15 PM
Nismokingz33's Avatar
Nismokingz33
I just bought that exact works bell hub....how does it break like that???
Old Aug 10, 2009 | 08:09 AM
SpeedNStylez_JL
The metal is cast on the works bell hubs...too much pressure and it cracks
Old Aug 10, 2009 | 03:06 PM
Nismokingz33
So I should upgrade asap right?? will it break off while driving???
Old Jul 21, 2012 | 02:46 PM
350monZter's Avatar
350monZter
your wheel is one in closer....
to you
or the dash
thanks
Old Jul 21, 2012 | 05:44 PM
SR71's Avatar
SR71
Lead Super Moderator
to you
or the dash
thanks
To the driver.
Dsowe
Feb 17, 2021 10:38 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
SharX59
Sep 27, 2015 09:23 AM
