What other prep do i need to paint bondo
Old Jan 16, 2009 | 05:46 PM
adamtaylorpcb's Avatar
adamtaylorpcb
Default What other prep do i need to paint bondo
im painting my kick panels soon. i glassed in some pods and bondo'd over that. sanded with 80 then 150 grit till it was smooth. any other prep i need?
i have filler primer, paint and clear already
Old Jan 22, 2009 | 07:04 AM
Caravanshaka's Avatar
Caravanshaka
Filler primer is used for smoothing the surface even more, so only use that if you don't think they are smooth enough yet.
If you don't want to go cheap on it, you'll want to epoxy primer (which will seal underneath), then use your filler primer since the epoxy won't be sandable. Then base and clear coat.
Old Jan 22, 2009 | 07:25 AM
sintaxeror's Avatar
sintaxeror
You need to sand the fiberglass/bondo smooth to 400 grit, then use filler primer. There is no need to seal them with epoxy primer, as fiberglass does not oxidize.
Old Jan 22, 2009 | 08:48 AM
Caravanshaka
While that is true of fiberglass, sealer will help assure that you do not have any chemical reactions between the paint and anything underneath the epoxy. A good habit to get in to if you ever go into restoring (I have a '66 mustang GT)
Rev_Night
Nov 7, 2020 06:00 PM
Cashwin
Oct 1, 2015 06:36 AM
