Air/Fuel Gauge Install Question
Old Feb 1, 2009 | 09:37 PM
mikeSSD's Avatar
mikeSSD
Default Air/Fuel Gauge Install Question
hey guys..i was wondering which color wire do i splice the sensor wire from the gauge to on the O2 sensor? i couldn't find a DIY. if anybody can provide a link it would be much appreciated. thanks!
Old Feb 2, 2009 | 04:21 AM
ErkTheJerk73's Avatar
ErkTheJerk73
www.plxdevices.com
Old Feb 2, 2009 | 10:43 PM
mikeSSD's Avatar
mikeSSD
thanks for the link but i cant find the installation section
Old Feb 3, 2009 | 08:05 AM
bswanny's Avatar
bswanny
Hey, I tapped into the Body Control harness below the fuse box for the power source. It was a red wire but I'll double check. The pin number is 38. I'll double check tonight.
Old Feb 3, 2009 | 06:14 PM
mikeSSD's Avatar
mikeSSD
thanks
Old Feb 4, 2009 | 04:06 PM
mikeSSD's Avatar
mikeSSD
anyone else have any input?
Old Feb 5, 2009 | 10:28 PM
mikeSSD's Avatar
mikeSSD
BUMP!
Old Feb 18, 2009 | 08:11 AM
350Z86's Avatar
350Z86
i could use a hand on this as well, i'm about to buy a gauge and pod and would like to get a diy from someone on istalling the air/fuel, and oil temp. also have a boost gauge but no boost
Old Feb 18, 2009 | 03:20 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
true air fuel gauges come with their own sensors
are you trying to hook up one of the blinkey-blinkey light Autometer type units that splice into the existing 02 sensors? If so, tbh, utterly useless, they tell you nada, but here ya go
http://www.autometer.com/productPDF/0837L.pdf
if you're doing a wideband, use something that has a keyed on power, preferably close by where you are going to mount the gauge so you don't end up with a rats nest worth of stuff. Test light will tell you what is constant, key-on, and ground
Old Feb 20, 2009 | 11:40 AM
350Z86's Avatar
350Z86
can anyone offer pics of there install?
Old Mar 20, 2009 | 01:11 AM
finalforce's Avatar
finalforce
Any updates on the install? Here's the basic layout of the diagram on this link posted previously: http://www.autometer.com/productPDF/0837L.pdf
Please anyone correct me if I am wrong. I'm looking to dip into this gauge shortly.
______________________
Red wire: to ignition
Black wire: ground
Violet wire: taps off of powertrain control module (PCM) which is the grey wire behind the air con/heater ****.
White wire: illumination
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Calinismo350z
Sep 14, 2015 04:04 PM
