Z part weights... with pictures
Old Dec 29, 2011 | 12:04 PM
  #61
RandomHer0's Avatar
RandomHer0
(G35) Used HKS true Dual Exhaust - 62.8LBS
Old Dec 29, 2011 | 05:00 PM
  #62
2TH PWR's Avatar
2TH PWR
Soooo Heavy!
My plan is now to just crawl under there on track days and unbolt it
All joking aside. I saw a guy at TMP do this with his M3, and no one stopped him.
Old Dec 30, 2011 | 10:03 PM
  #63
GT-Rob's Avatar
GT-Rob
Nasty, but its a nice sounding piece. I was actually close to buying the JIC ti, I think its around 9lbs. You have to go single exit to really save a lot.
Drivers seat was just under 50lbs (46 I think). Passenger not as much due to only 1 motor, but heavy chairs for sure. My new seats are 13lbs each. Aiming to get the car into the low 2800s dry.
Carpet came out today, didn't seem to weigh more than maybe 2lbs total. The stuff under it though, has to be at least 10lbs worth of **** stuck to the chassis.
Old Dec 31, 2011 | 12:00 AM
  #64
Resmarted's Avatar
Resmarted
vq35de block+main caps is 62lbs
vq35de crank is 42.2lbs
Old Dec 31, 2011 | 07:48 AM
  #65
RandomHer0's Avatar
RandomHer0
Originally Posted by 2TH PWR
Soooo Heavy!
Yeah; I actually thought it would be more.
I'm kinda limited in my options it seems.
Greddy TT - need flow but also want lightness.
Looking at the Greddy Turbo Ti-C now, shipping weight is 88lbs apparently, I wish I knew the actual weight.
Also thinking about just getting a custom single built.
Old Jan 14, 2012 | 09:35 AM
  #66
GT-Rob's Avatar
GT-Rob
for those looking for more head room...
roof liner - 4lbs
Curtain air bags (pair) - 4lbs
Visors (pair) - 1.4lbs
Old Jan 14, 2012 | 02:59 PM
  #67
RandomHer0's Avatar
RandomHer0
Soooo Heavy!
Sooo...ended up with AAM 3" Single. Gorgeous piece IMO, welding is amazing.
Y-Pipe back is 23lbs.
Y-Pipe is 11.8
G35 Extension Piece about 2.8.
=37.6lbs
a savings of 25.2lbs vs. HKS
Old Jan 14, 2012 | 04:41 PM
  #68
2TH PWR's Avatar
2TH PWR
I will copy you.
Old Jan 17, 2012 | 07:53 PM
  #69
2TH PWR's Avatar
2TH PWR
Anybody get the braille 6.9 pound battery? Am I asking for problems holding charge?
Old Jan 17, 2012 | 09:28 PM
  #70
03threefiftyz's Avatar
03threefiftyz
If you drive it everyday you will be fine, but if not you will want to hook it up to a tender. I use the 11lb one and it is fine to leave for a week, but after that it gets sluggish firing the motor up.
Old Jan 18, 2012 | 05:55 AM
  #71
GT-Rob's Avatar
GT-Rob
I've heard they only last a few days. I personally would carry a portable booster if you go with it.
I've got a 13lb one and was told by a local shop that the guy uses it to start his V8 mustang after it sits for a few months.
Old Jan 19, 2012 | 09:51 AM
  #72
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
The little batteries usually have low CCA (cold crank amp) ratings, so if you live in a region where the temps are low, you will most likely need to jump your car. I've had the Braille's 11 or 13 lbs battery a few years back and was not impressed. Even during TX's weaksauce winters, it struggled a bit.
Old Feb 12, 2012 | 08:48 AM
  #73
xman2yman's Avatar
xman2yman
Anyone know the weight of the spring bucket and what the weight of toe arms? Also stock suspension weight?
Old Feb 23, 2012 | 05:04 AM
  #74
hazehkg's Avatar
hazehkg
Originally Posted by Archaismic
rear hatch
rear hatch weight
So rear hatch is 53lbs?
Old Mar 9, 2012 | 10:05 AM
  #75
GT-Rob's Avatar
GT-Rob
Factory mirror: 2.2lbs each
APR mirror: 0.2lbs each
Old Mar 14, 2012 | 10:22 PM
  #76
Archaismic's Avatar
Archaismic
originally i said correct but no... the hatch weight pic is BELOW the hatch and it's 47lbs
Old Mar 14, 2012 | 11:08 PM
  #77
KingBaby's Avatar
KingBaby
Hardest Setting
O look....it's one of my favorite threads!
Old Mar 14, 2012 | 11:38 PM
  #78
Archaismic's Avatar
Archaismic
lol thanks! i've been slacking pretty bad but it looks like others have kept things pretty well alive
Old Mar 16, 2012 | 12:37 PM
  #79
GT-Rob's Avatar
GT-Rob
Stock '03 hood - 22lbs
Gutted '03 hood - 14lbs
Old Mar 24, 2012 | 06:13 PM
  #80
GT-Rob's Avatar
GT-Rob
A/C system (compressor, condenser, adjuster, belt, some lines): 26lbs
