Z part weights... with pictures
Old Mar 24, 2012 | 11:39 PM
  #81
Archaismic's Avatar
Archaismic
getting a baby scale soon... i'll get to weigh small parts on there WOOOT
Old Apr 7, 2012 | 03:42 PM
  #82
GT-Rob's Avatar
GT-Rob
Headlights - 6.1lbs each
Old Apr 15, 2012 | 12:19 PM
  #83
2TH PWR's Avatar
2TH PWR
Metal speaker and glovebox housing behind seats.
No less than 27.2 pounds. I left a band of metal around the seat belts and down across the front next to the electrical wires that run along there.
Estimate an additional 3 to 7 lbs can be stripped...
Old Apr 19, 2012 | 07:19 AM
  #84
GT-Rob's Avatar
GT-Rob
OEM front fenders (including dirt) - 7.5lbs each
Old Apr 20, 2012 | 02:04 PM
  #85
GT-Rob's Avatar
GT-Rob
Door windows - 11lbs each
Old Apr 20, 2012 | 04:16 PM
  #86
Quamen's Avatar
Quamen
Love this threa! It's nice to actually see the weights since I have removed nearly everything in the thread. I was able to get my car to 2,700lbs with an LS1 and heavy a$$ TH400 so I'm excited to see what some of the normal Z's get down to.
Old May 1, 2012 | 08:34 PM
  #87
GT-Rob's Avatar
GT-Rob
Sitting at 2720 right now without aero.
No door windows, no pass seat, CF headlights and front fenders, gutted hood.
I imagine I could do low 2600 with CF hatch, lexan, rear shelf out, new suspension. Maybe break into 2500s but would be pushing it without a cage.
Old Aug 26, 2012 | 09:30 AM
  #88
Z33_Taxi's Avatar
Z33_Taxi
This is the exact sort of thread I was looking for. I'm starting to tear down the Z for a track prep. Here's the XO2 exhaust and components Sorry about the shitty scale pics
Magnaflow 12468 Satin Stainless Steel 2.5" Dual Oval Muffler:9LBS
The part that connects to the actually muffler5LBS
Each muffler weigh:9LBS
Piece coming off the cats:18LBS
All together it weighs 41LBSI don't know what the final product will weight when I cut out the resonators and put the Magnaflow x pipe. The stock resonators do feel quiet a bit heavier and I may just run pipping from the cats to the X pipe and then piping to the mufflers. we'll see. Hopefully I remember and take pics with weight
Old Sep 6, 2012 | 08:41 PM
  #89
G&Z's Avatar
G&Z
Anyone know what will happen if you remove this mt transmission counter weight?
Old Sep 22, 2012 | 04:35 AM
  #90
Quamen's Avatar
Quamen
This is the racecar on Intercomp scales with all fluids, full gas tank, cage and LS1/TH400. Keep in mind this is a 535whp drag car not a street car. Going to do a light weight battery and drag brakes up front this winter.
Old Sep 24, 2012 | 03:49 PM
  #91
mvp2765's Avatar
mvp2765
Nuts. Should have only had 1/4 tank of gas tho. No one mentioned aftermarket sways versus stock
Old Sep 26, 2012 | 12:51 PM
  #92
3rd_gear's Avatar
3rd_gear
Car becomes lighter....jk.
Let us know what happens.
Old Nov 16, 2012 | 05:36 PM
  #93
vtchang's Avatar
vtchang
Not sure if this is where it goes, but at least its documented.
OMP Universal Sliders (HC 665) - 5.6lbs
Planted Seat Base - 8lbs
*Will update later with Status Ring, Status Brackets, and Bride FG
Attached Thumbnails Z part weights... with pictures-planted_350z_driver_side.jpg   Z part weights... with pictures-omp_universal_sliders.jpg
Old Nov 16, 2012 | 05:55 PM
  #94
misterniceguy's Avatar
misterniceguy
03 passenger airbag= 5.478 lbs
Attached Thumbnails Z part weights... with pictures-pc060085.jpg   Z part weights... with pictures-pc060086.jpg
Old Dec 6, 2012 | 05:56 PM
  #95
misterniceguy
Driver interior door panel without controls or elbow rest pad= 6.426 lbs.
It is leaning on the wall, but it's very close to being balanced. So if anything, it might be just a hair heavier.
Attached Thumbnails Z part weights... with pictures-pc060083.jpg   Z part weights... with pictures-pc060085.jpg
Old Dec 22, 2012 | 03:15 PM
  #96
timmywhatsup's Avatar
timmywhatsup
Does anyone know what the weight of the factory suspension is? Struts, coils etc? There has to be some potentially significant weight savings there, and I believe half of it would be considered unsprung.
Old Dec 22, 2012 | 04:34 PM
  #97
Z33_Taxi's Avatar
Z33_Taxi
Just a re cap on this. I installed everything today so the 2.5" HKS replica w/ the X pipe mod weighs in at 35 pounds.
Old Jan 18, 2013 | 12:11 AM
  #98
samsniss350z's Avatar
samsniss350z
I'd be interested to know just how heavy the leather drivers seat complete with both electric motors weighs as i've a feeling it weighs as much as i do and the front leather seat with the single electric motor not much different. Imagine the saving with a couple of light bucket seats?
Old Feb 15, 2013 | 02:27 PM
  #99
Z33_Taxi's Avatar
Z33_Taxi
I can do this tomorrow for you, I'll be ripping out the carpet for cleaning. IIRC they are 35ish pounds
Old Feb 15, 2013 | 06:15 PM
  #100
bealljk's Avatar
bealljk
In my 2003 touring, the drivers side seat (leather, two motor, airbag, etc) was right at 50lbs. The passenger side was about 48lbs.
I bought a sparco pro2000 and it was about 20lbs and about 5lbs for the seat bracket…Delta, 75lbs...
