Waxed the coupe
Old Feb 13, 2009 | 12:08 AM
brink2012's Avatar
brink2012
Default Waxed the coupe
Got around to waxing today. I did the Seafoaming treatment through the brake booster line because I heard nothing but good reviews, it seemed to help a bit. The car drives great.. but either the clutch is going out or I'm still not used to driving it (1st long-term stick car). Fun car either way, I'm loving it.. it's nice expecting people to turn their heads when you drive by.
Is there a certain way to tell if the clutch is going out for sure? I do have a 2 year / 24,000mi extended warranty but I understand that the clutch is not covered under the factory warranty... Also I have that grinding 3rd gear which I understand was covered? anyone have any clue?
Old Feb 13, 2009 | 01:44 AM
mcarther101's Avatar
mcarther101
Your transmission should be replaced if you're grinding always into 3rd. You've got a bad syncro.
If when you accelerate greatly (or @ wide open throttle), but the engine revs up... and you go nowhere - then your clutch is bad. It's called slippage. Engine says go, clutch says no.
Old Feb 13, 2009 | 07:46 AM
brink2012's Avatar
brink2012
I don't always grind into 3rd.. just sometimes and mostly when the car is cold.. How long does it take a shop to replace the syncro.. and is this covered under the mfg warranty?
Old Feb 16, 2009 | 12:32 PM
white_sg's Avatar
white_sg
ditto on 3rd gear grinding, it seems like it does it when its cold and going from 2nd into 3rd before 2000rpm, I was told by a stealership its not covered in factory warranty and Im asking again in this thread. Another thread said it was.
Old Feb 16, 2009 | 12:41 PM
Chromex319's Avatar
Chromex319
this thread has a serious identity crisis.
Old Feb 16, 2009 | 12:55 PM
white_sg's Avatar
white_sg
lol
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Jambo016
Sep 16, 2016 01:08 PM
seagrasser
Oct 11, 2015 03:27 PM
dcains
Sep 21, 2015 09:28 AM
