Carbon Fiber Vinyl Pattern Wrap Thread
Old Dec 24, 2011 | 02:54 PM
  #661
ambushphoto's Avatar
ambushphoto
Ideally you would want to use a sheet of dinoc big enough to cover the entire part. It looks like you have a seam half way through just below your climate control *****. Over time that will curl up from being exposed to the sun and stuff.
Old Dec 24, 2011 | 02:57 PM
  #662
SatinBlack's Avatar
SatinBlack
Thanks a lot, finally a decent comment on my experiments
Also this thread merging **** is crazy...
Old Dec 28, 2011 | 08:50 PM
  #663
Fluid1's Avatar
Fluid1
damnit.
Old Dec 28, 2011 | 09:10 PM
  #664
DViper0020's Avatar
DViper0020
Anyone have a good site where I can order some of this cf vinyl? I've read through a few of these threads about cf wrapping the interior and I've come to the conclusion that I want to do this to my car! Lol.
I've never "wrapped" anything before, but I'm pretty confident that I can do it. I was wondering if you guys could tell me how much I should get? I would like to do the center of the dash like I've seen on most of the interior wraps, but I'd also like to do my door switch area, possibly the black area on the door in between the handle and vent, and I was thinking maybe some pieces to the center console, but I'm not 100% sure about it.
I'd appreciate any advice and I'll give a thanks in advance.
Old Dec 28, 2011 | 09:18 PM
  #665
Bmurray350z's Avatar
Bmurray350z
http://www.ebay.com/itm/220892358821...84.m1438.l2649
Old Dec 28, 2011 | 09:19 PM
  #666
Resmarted's Avatar
Resmarted
Originally Posted by TPete19
There's tons of info about in here, just spend some time searching, or PM me and I can give you advice. I've done a few of the center consoles now and can point out many of the potential trouble spots.
You will definitely want to use primer 94 on it.
Here are some pics of mine. As you'll see in the second pic, the corners have a tendency to want to retract back to their original shape. I obviously didn't get that little spot primed correctly.
Wow man, that's probably the best looking z33 center console i've ever seen! props. Usually that cf wrap looks like sh*t imho. Not a fan of the shifter, but the alcantra style door wrap is a very very nice touch.
Old Dec 28, 2011 | 11:03 PM
  #667
KushZEN's Avatar
KushZEN
I would not recommend the 3M Dinoc. As most have stated, dinoc is very hard to work with and very permanent. Most of us use the 3M Scotchprint, I bought my roll from metrorestyling.
Old Dec 29, 2011 | 09:15 AM
  #668
DViper0020's Avatar
DViper0020
I seen that the dinoc is avoided, so I was leaning toward the scotchprint. You think 60"x24" is going to be a good amount for doing my interior?
Old Dec 29, 2011 | 12:11 PM
  #669
MeinVinyl's Avatar
MeinVinyl
I've used the DiNoc for numerous applications and haven't had many issues. The first headlight shrouds that I did had some bubbles, but it was a test anyways and have been much closer to flawless since then. DiNoc is not very hard to work with if you have the right materials, imo.
Old Dec 29, 2011 | 01:45 PM
  #670
Ak48z's Avatar
Ak48z
It is definitely not permanent... and it was pretty easy to work with.
Old Dec 29, 2011 | 02:28 PM
  #671
KushZEN's Avatar
KushZEN
From what I have seen, It is very permanent. A friend of mine did his interior on his BMW with dinoc, and after taking it off, it has ruined the finish of his interior pieces. After reading around, we found out that he wasn't the only one with this problem.
Old Dec 29, 2011 | 02:31 PM
  #672
Waiz's Avatar
Waiz
Threads merged......again
Old Dec 29, 2011 | 03:05 PM
  #673
Ak48z's Avatar
Ak48z
May be unfortunate for BMW plastic, but I have wrapped pieces and months later ripped it off, looked just like it did before the wrap. So from first hand experience, it is not permanent by itself.
Old Dec 29, 2011 | 09:02 PM
  #674
TPete19's Avatar
TPete19
Depends on the substrate. I prefer the Scotchprint and have covered a number of pieces for different people. Pulls off without issue. I've only dealt with Dinoc for one small piece (maybe 15 square inches) and it seemed to do alright too. Dinoc is definitely thicker and I don't like the texture as much.
Old Dec 30, 2011 | 06:20 AM
  #675
MeinVinyl's Avatar
MeinVinyl
I have removed the DiNoc from a front grill, rear spoiler, front lip, engine cover and even a roof. Didn't have any problems with the plastic parts but we did have to buff out the roof of the car. That's about it. Cleaning up a little residue left behind should be expected from any QUALITY vinyl. My experience with competitor's "carbon like" vinyl is the vinyl either ripped, split layers (color layer and adhesive layer) or had to be sand blasted to be removed.
That's my personal experience with the stuff.
Old Jan 2, 2012 | 03:35 PM
  #676
Atl_Adam's Avatar
Atl_Adam
Ok...I'm done. I've been trying to wrap a few interior pieces and I cant get the edges to stick. I've taken them off and tried and tried all weekend, I just cant get it to look good. I would be willing to send my materials and interior pieces to someone if they would be willing to help a fellow Z owner out.
I'm located in Atlanta.
Old Jan 2, 2012 | 04:20 PM
  #677
Ak48z's Avatar
Ak48z
Are you using the Primer 94 at all? I have done it both with and without, I never really had an issue getting the material to stick to the edges. Just heat/stretch over the edges then trim it up.
Without the primer 94 though and a had a few edges start to bubble/come up after a couple of months in the summer.
Old Jan 2, 2012 | 04:27 PM
  #678
Atl_Adam's Avatar
Atl_Adam
I did not use primer of any sort as I heard mixed reviews of installing it both ways. I may just run the parts by a vinyl sign/sticker shop somewhere in Atlanta if I cant find anyone to help out.
Old Jan 3, 2012 | 05:45 AM
  #679
MeinVinyl's Avatar
MeinVinyl
If you don't know the shop they're going to charge out the A$$ (personal experience) for something you should be able to do quite easily. Be patient, order the Primer and be sure to apply in a warm room. Use a heat gun to make things work even better. This is a very easy thing to do.
I would say that I'd do it for you, but shipping isn't usually too cheap, depending what you're doing/covering.
Old Jan 3, 2012 | 07:23 PM
  #680
TPete19's Avatar
TPete19
Adam,
Just grab a small can of Primer 94 and a couple cheap brushes. Brush a fine layer on the edges, then let it tack and you'll be good to go.
