Problems installing OEM mud guards
Old Feb 23, 2009 | 08:54 AM
donkinuts's Avatar
donkinuts
Default Problems installing OEM mud guards
I have a set of mud guards(front) for my "08 PPW. The problem is that the spring clip, is not the right size. For those that have done this install, you probably know what part I am talking about. This is sort of like a tiny money clip, that gives you a place for the screw to "screw into".
I went to a few dealerships and they say it is the right size part. That can't be, as the hole on the panel and the mudguard does not line up with the hole on the clip. The dealer can do this job in under an hour, but I am guessing they are just going to drill or glue the mud guard on; seeing that the fitment is bad. Are there anyone people out there that had this same problem when installing their mud guards?
Old Feb 23, 2009 | 09:42 AM
I have replaced the mud guards several times without incident. I used painters tape to align and keep the clips from moving.
Old Feb 23, 2009 | 10:07 AM
donkinuts's Avatar
donkinuts
So you are using just the tape to keep the clip fastened onto the mud guard and plastic body panel? Hmmm, that seems like a crude way to do it. The instruction booklet for this actually shows that you have to hook the clip onto the panel inside the wheel well. Then you screw a bolt on top of the mudguard and into the clip.
Old Feb 23, 2009 | 11:44 AM
Correct. The clip goes on the body panel. But sometimes it does not fit tight and falls a little. I just used some tape to help hold it in place.
Old Feb 23, 2009 | 12:49 PM
donkinuts's Avatar
donkinuts
The problem I am having is that when they are clipped on, the hole on the clip does not line up with the hole on the body panel. The clips are too short, but the dealership swear that they are the right sized clips. I might have to resort to drilling or something a la Macgyver.
liqalu04
Jan 2, 2022 12:58 PM
Dymsi
Sep 29, 2015 11:32 AM
codek
Sep 28, 2015 03:03 AM
SharX59
Sep 27, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
