The install looks very professional, but I think you could have chosen some lights that flow with the car's style a little better. That being said nice job on the install.
Part of the problem in selecting a fog light is the curve (Looking down over the hood) of the bumper, as you go away from the tire towards the center, the center line moves out. This means the outer lens of the light must do the same if it is to be body line flush. The only fog lights I found that could work in this manor are the crappy a$$ toy-ota camry/es300 fog lights but the Z lacks sufficient room behind the bumper cover. If I had used a light with a flat lens then to be flush, the lights would have been aimed at the sidewalk. I used a light with a dome lens to not look obtuse as a flat lens would have appeared
plus there would either be an angled edge protruding on one side or a cavity on the other due to the curvature.
