OEM Window switch panel
Old Mar 15, 2009 | 03:43 PM
pistols07Z's Avatar
pistols07Z
Default OEM Window switch panel
Hey Guys, my driver side window switch panel the finish is all scratched and chipped up. It really bugs me because the rest of my car is mint.
Where can I buy an OEM replacements? Anybody know the part numbers?
Old Mar 15, 2009 | 03:53 PM
pistols07Z's Avatar
pistols07Z
Also, how about the door for the empty console area above the radio where the navi would be...
Old Mar 15, 2009 | 04:19 PM
CSF's Avatar
CSF
this help?
http://www.courtesyparts.com/350z-pa...5_846_857.html
http://www.courtesyparts.com/350z-pa...5_824_834.html
Old Mar 16, 2009 | 10:43 AM
pistols07Z's Avatar
pistols07Z
thats it! Does anybody have a how-to on replacing that window switch panel piece??
Old Jun 2, 2009 | 11:06 AM
Louis21's Avatar
Louis21
Did you ever replace this? My cover looks like crap too...how on earth did it get all those scratches beats me. It's not like i keep my nails long, I'm guessing the seatbelt buckle somehow hits it when it retracts.....
I think it just pops out (mine's an 07) no screws but i am not sure. I've neen procrastinating in replacing mine.
Old Jun 2, 2009 | 11:26 AM
Blazemaster's Avatar
Blazemaster
Easy, on the 03-05s, there's a little screw in the little hole that acts as a door handle. It's covered by a rubber cap, once you pop off the rubber cap, you will see it. You just need a butter knife, or a flat head screw driver for the rest. It just takes a bit of pulling and pushing it will come off. If I remember correctly you'd have to remove the arm rest also, because the arm rest may have a snap that holds the window switch down. Just be patient when you're pulling it off, pull with constant pressure and pop it out of the snaps one at a time.
There's plenty of DIY threads that shows how to remove the entire door panels with picures.... try searching next time.
Old Jun 2, 2009 | 01:48 PM
lbz's Avatar
lbz
instead of buying new parts, try this first.
Get a can of Dupli-Color Vinyl and Fabric, Flat Black and hit it with that. If you are unhappy, only out $6 or so.
I did mine, came out pretty good. There is a bit more light reflection off the surface and the color match with the vinyl arm rest area is not exact but, I don't even notice anymore.
350z82
Oct 1, 2015 06:25 PM
