interior lights wont come on
Old Apr 23, 2009 | 09:11 PM
Paintballislife's Avatar
Paintballislife
Default interior lights wont come on
OK, so i was ****ing around and tried to hook up some footwell lights, running off of the interior map lights, had something backwards and shorted them out, so i pulled the battery. Now they will come on if you push them, but wont come on with the door open or anything. Ideas?
Old Apr 23, 2009 | 11:15 PM
BlowinGreen's Avatar
BlowinGreen
you prolly messed more than this up, but when i bought my car none of my interior lights worked. all i did was open both doors, disconnect the battery for about 10 minutes, and connect it back up. everything worked for me after that. hope that helps.
Old Apr 24, 2009 | 07:44 AM
Paintballislife
i dont think i did any real damage, i will try opening bpth doors
Old Apr 24, 2009 | 10:40 AM
kevincat's Avatar
kevincat
what he did was resetting the ecu and not necessarily just opening the doors. but do try unplugging the battery for 15 minutes and see if that helps.
Old Apr 24, 2009 | 10:43 AM
aDDandrew's Avatar
aDDandrew
fuse?
Old Apr 24, 2009 | 02:31 PM
Paintballislife
i will pull the batt, guess i will try to let it sit longer
Old Apr 24, 2009 | 04:10 PM
shoopajae10's Avatar
shoopajae10
hit it a couple of times, it always works.
Old Apr 25, 2009 | 08:15 AM
kevincat's Avatar
kevincat
haha wth! ghetto fix will only get ghetto results. narrow down the possibility of the problem, so you would only need to get it fix once.
maybe there is a short somewhere that connect the dome to the door switch.
Old Apr 25, 2009 | 12:45 PM
Paintballislife
i dont know, i cant find anyhing, no fuses blown or anything, has to be in the ECU, i pulled the batt for 10 mins and opened both doors. nothing.
Old Apr 25, 2009 | 12:50 PM
kevincat's Avatar
kevincat
when you shorted the interior lights when trying to connect the footwell light, did the interior lights worked at all after that? or did it work after you pulled your battery.
Old Apr 25, 2009 | 01:31 PM
Paintballislife
they didnt work had to reset,and i thought they were on cause the door but i guess i had both on.
Old Apr 25, 2009 | 03:15 PM
kevincat's Avatar
kevincat
well i dunno if this will work or not but you can give it a shot.
try to intentionally short the interior lights or connected the footwell light directly to the dome lights while the battery is still connected. if the footwell light draw more power than the dome light then you will hear a faint buzz, this mean that the ecu has shuts off the lights. your vanity lights and interior lights will not work.
so now unplug the neg. part of the battery.
pump the brakes a few times
let sit for 15-30 minutes, longer if you can afford too.
and maybe it will work this time.
hopefully this helps
Old Apr 25, 2009 | 04:06 PM
Voboy's Avatar
Voboy
check the fuse box in your driver's side footwell on the left. i believe you blew one of the fuses....just to make sure locate the correct fuse for the interior lights and replace it with the spare and see if the lights work. sometimes its hard to spot a blown fuse with the naked eye.
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
350z82
Oct 1, 2015 06:25 PM
