NEED HELP. Will these rims fit my car?!
Old May 28, 2009 | 07:18 AM
Originally Posted by mcarther101
http://www.1010tires.com/WheelOffsetCalculator.asp
06' Stock wheel specs:
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
Use that. Plug in stock wheel specs and new wheel specs. It will tell you how much further the wheel will stick out, or be sunken in. With a 35mm offset it will look just about the same as stock. The rear wheels offsets are good though, although if you want the flush look you should look for a 19x10.5 +20ish, or 19x9.5 +10...15ish
I'd pass on those wheels.
Good post. Members should use the calculator, and make their own “Does it fit?” decisions.
Chris350z03
Oct 8, 2023 07:19 PM
SonnyWu
Nov 24, 2015 08:19 PM
Ronso
Oct 30, 2015 12:39 PM
Mw870
Sep 10, 2015 07:50 PM
PureR3d
Sep 10, 2015 06:23 PM
